Best Overall AV for my new Polk 7.1 Setup!
beachbumcaz
Hey guys,
Very new to this but have been doing alot of research. I'm looking for a very new mid-range receiver (best bang for the buck). I'd like to potentially put in an XPA amp down the road to give a bit extra (let me know if my setup is worth it) so I'd like to have some available pre-outs.
My setup so far consists of:
Polk RTi A9's (x2)
Polk RTI CSi A6 Center
Polk FXi A6 (x4)
DSW PRO 600
Thanks in advance!
Cheers
Matt
Polk RTi A9's (x2)
Polk FXi A6 (x4)
DSW PRO 600
Thanks in advance!
Cheers
Matt
Post edited by beachbumcaz on
PS I don't really care about 3d if that makes any difference
Budget ???
I was thinking around 700-1000. Wasn't sure if they had any good deals going on either . . .
bump
See if you can get a Denon 3310.Things are more like they are now than they ever will be!
Pioneer Elite SC series on clearance if you can....Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
+1 on this. SC-25/27 is definitely in the budget. You may not even need an amp with this AVR.Shoot the jumper.....................BALLIN.............!!!!!
Are the ICE amps all they are cracked up to be? I'm basically down to the 1120 and the SC-25. Not sure if it's worth the extra money, or if I should just jump on the 1120's before they are all gone and be happy about it.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
IceAmps are very good, search the forum. Quite a few of us have these in our own setup.Shoot the jumper.....................BALLIN.............!!!!!
