What power cables..............
Are you currently running?
I am a pc fanatic!
Connectors/Receptacles/Power cables, I can't get enough of the AC side of this hobby!
I have more in dedicated lines/receptacles/powercords/upgraded IEC inputs/connectors than you can imagine!
Alot of people collect plates/beenie babies/records, ect.
I collect AC tweaks and all that goes with that!
I spend more on heat shrink/Deoxit/wire/connectors than most people spend on their system!
Anyone else addicted?
I can take a small BS system and make it sound pretty good with some GREAT AC power.
I am a pc fanatic!
Three 20 amp circuits. -
I love my PS Audio AC5'sThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I just finished burning in a PS Audio AC12 to complete my power upgade, I have an AC10 on the Quintet and AC3's on the preamp and sources and the aC12 on the amp all I can say is WOW!! Every good thing you read about the AC12 is true.:biggrin:
Pangea makes some great affordable cables!
I have used Zu Cables since I returned to this hobby and now have Zu Mother PCs on all my equipment. Do not know alot about the new Zu Mission or Event cables but, based on my experiance I would assume there is excellent value and performance for the dollar.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
2 pairs of Zu Mission, a Nordost Shiva and a Shunyata Diamondback[
I built my own power cords using furutech FI-11cu male,FI-11ag IECs and FP-314ag cable.I do prefer the signal cable digital reference with the camelot dragon due to synergy issues though.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
AuidoQuest NRG-3's:
2 amps
AVR
TV
AudioQuest NRG 1.5's:
Blu ray
Satellite HDIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
I use Pangea AC14SEs from my source components, and a giagantic AC-9 from my dedicated 15amp outlet to my Power Center.
My AVR, Sub, and Int Amp use PS Audio power cords.
I currently have a borrowed Transparent on my amp and a handmade from a polkie on my Pre. Can't say I can hear a difference, but everything matters!-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I do diy pc's with wire from Chris Venhaus: Flavor 2 on CDP, flavor 4 on power amp.
I have several other ac tweaks installed including Alan Maher's parallel choke. I've also tried to address RFI/EMI through the use of speaker cable filters (zobel networks) at the amp and speaker end, and the use of quartz amethyst crystals at strategic spots.
Although all of the above has been effective, the crystals have yielded the biggest improvement in terms of cleaning up a stridency I didn't know was there until it was gone!
Cheers,
Fred"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
100% Signal Cable.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
JonBilt cable custom power cord.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I found this this power cord being thrown out. It was attached to an 8 track player. I could see all the wires, and many of them were frayed, but I plugged it in and it worked, so that's what I use.
Seriously, it's something I haven't even gotten into. I have one Pangea, and the rest are just stock cords that came with whatever I bought. Only reason I got the Pangea was because I bought a preamp that did not come with a power cord.
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
Garden variety zip cord.:redface:
Ok, I'm really new to the 'upgraded' power cords. I understand that if your using a PC that is too small (generates heat, etc) that this may affect current quality, and therefore sound quality. I'm not saying this phenomenon doesnt exist. I know that cables used for interconnects, speakers, etc. can make a large difference, but this has been documented not only objectively (and your specific choice will vary depending upon your equipment, room, audio preferences, etc.), but subjectively as well (i.e. the measurements DarqueKnight did with AI-1 Dreadnaught project). Has anyone done any subjective tests on PCs?SDA SRS modded: Xovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDOd, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
