Polk PSW125 230V to 110V Conversion
dkhurana94539
dkhurana94539 Posts: 3
edited January 2011 in DIY, Mods & Tweaks
Can I convert a Polk PSW125 from 230V to 110V? I purchased a unit in India and wish to use it in USA. Is there a kit or list of components I may purchase to do this?
Post edited by dkhurana94539 on
  • Systems
    Systems Posts: 14,873
    edited January 2011
    Not 100% sure, but I think you will have to have a step down transformer, because of the 60hz needed.
    Maybe someone with more experience can chime in.
    Welcome to Club Polk!
    Testing
    Testing
    Testing
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    Did you look closely at the back of the subwoofer, on the amplifier?
  • dkhurana94539
    edited January 2011
    Thank you. yes I checked the rear of the PSW 125 and it indicates 230V 50/60Hz. since it's a DC device, the frequency won't matter.
  • dorokusai
    edited January 2011
    The reason I asked is because I thought it was switchable on the rear in regards to country and voltage. Sorry. I double checked the manual and as you already know, it isn't.
    Like Pepster stated previously, you need a step down transformer.
  • dkhurana94539
    edited January 2011
    thank you anonymouse. I believe your suggestion to purchase a replacement plate amplifier that works and is outfitted for use in an 110V environment is the right approach. thank you!!
