Polk PSW125 230V to 110V Conversion
dkhurana94539
Can I convert a Polk PSW125 from 230V to 110V? I purchased a unit in India and wish to use it in USA. Is there a kit or list of components I may purchase to do this?
Not 100% sure, but I think you will have to have a step down transformer, because of the 60hz needed.
Maybe someone with more experience can chime in.
Welcome to Club Polk!Testing
Testing
Testing -
Did you look closely at the back of the subwoofer, on the amplifier?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thank you. yes I checked the rear of the PSW 125 and it indicates 230V 50/60Hz. since it's a DC device, the frequency won't matter.
dkhurana94539 wrote: »Thank you. yes I checked the rear of the PSW 125 and it indicates 230V 50/60Hz. since it's a DC device, the frequency won't matter.
The reason I asked is because I thought it was switchable on the rear in regards to country and voltage. Sorry. I double checked the manual and as you already know, it isn't.
Like Pepster stated previously, you need a step down transformer.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
thank you anonymouse. I believe your suggestion to purchase a replacement plate amplifier that works and is outfitted for use in an 110V environment is the right approach. thank you!!
