ACME Audio Labs
Outfitter03
Outfitter03 Posts: 563
edited January 2011 in 2 Channel Audio
Not just for Wile E. Coyote anymore.
http://www.acmeaudiolabs.com/products.htm
I found this site in search for an affordable upgrade receptacle. They offer one that is Silver Plated, high copper brass that is Cryo treated for $35 dollars. Thought of trying one as this is in my budget ball park and would be better than my current receptacle.
Does anyone have any experience with this vendor?
Also they offer cryo treated silver fuses for $12. I am in the process of upgrading a set of Monitor 10As and thought these might be a good match. Shipping is reasonable also, $5.50 for up to 4 items.
Feedback on Vendor or Receptacles would be appreciated. I live in a rental so I cannot run a dedicated line, but due to existing wiring my electronics is on one circuit.
    edited January 2011
    Never heard of them, but the only thing I can say about ACME is, things didn't work out too well for the coyote now did they ?
  • WilliamM2
    WilliamM2 Posts: 4,812
    edited January 2011
    Make sure you get the $40 to $70 wall plates or you won't get the full benefit of the new receptacles.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    WilliamM2 wrote: »
    Agreed,and the Myrtlewood cable tuning device is a must have.:wink:
  • bikerboy
    bikerboy Posts: 1,242
    edited January 2011
    The IEC, fuses, and fuse holders look good. Dont see the rest as much good. Never heard of them before. let us know if you try any of their stuff.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • fbm211
    fbm211 Posts: 1,488
    edited January 2011
    Ive heard of them.Moon audio sells them and Ive seen them pop up on audiogon from time to time.I thinnk you would be better off trying the porter port wall outlet though as they have gotten good user reviews.
    Im going to try one of these>> http://www.audiogon.com/cgi-bin/cls.pl?powrdist&1297200036&/Atl-Etp-1000cu-Pure-Copper-Outlets
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Outfitter03
    edited January 2011
    Thanks fbm211, I just linked to that site through Audiogon and will give one a try. Appreciate your assistance.
