ACME Audio Labs
Outfitter03
Not just for Wile E. Coyote anymore.
http://www.acmeaudiolabs.com/products.htm
I found this site in search for an affordable upgrade receptacle. They offer one that is Silver Plated, high copper brass that is Cryo treated for $35 dollars. Thought of trying one as this is in my budget ball park and would be better than my current receptacle.
Does anyone have any experience with this vendor?
Also they offer cryo treated silver fuses for $12. I am in the process of upgrading a set of Monitor 10As and thought these might be a good match. Shipping is reasonable also, $5.50 for up to 4 items.
Feedback on Vendor or Receptacles would be appreciated. I live in a rental so I cannot run a dedicated line, but due to existing wiring my electronics is on one circuit.
Post edited by Outfitter03 on
Never heard of them, but the only thing I can say about ACME is, things didn't work out too well for the coyote now did they ?HT SYSTEM-
lsi 9's -
Make sure you get the $40 to $70 wall plates or you won't get the full benefit of the new receptacles.
Agreed,and the Myrtlewood cable tuning device is a must have.Make sure you get the $40 to $70 wall plates or you won't get the full benefit of the new receptacles.
The IEC, fuses, and fuse holders look good. Dont see the rest as much good. Never heard of them before. let us know if you try any of their stuff.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Ive heard of them.Moon audio sells them and Ive seen them pop up on audiogon from time to time.I thinnk you would be better off trying the porter port wall outlet though as they have gotten good user reviews.
Im going to try one of these>> http://www.audiogon.com/cgi-bin/cls.pl?powrdist&1297200036&/Atl-Etp-1000cu-Pure-Copper-OutletsSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Thanks fbm211, I just linked to that site through Audiogon and will give one a try. Appreciate your assistance.
