Setup of SurroundBar 300 to Sony KDL-46XBR6
insipid8
insipid8 Posts: 4
New Christmas present of course.
I've connected the optical audio out of my TV (Sony KDL-46XBR6) to the input of the SB3K.
I get no audio out of the SB3k.
I also changed the sound output of the TV to go completely external so that the audio out, still no sound from the SB3k.
I do see the LED light from optical cable.
Any thoughts?
Thanks and Merry Christmas.
Post edited by insipid8 on
  • nguyendot
    nguyendot Posts: 3,594
    edited December 2010
    Read the manual for the TV.
    Main Surround -
  • insipid8
    insipid8 Posts: 4
    I've read the TV Manual and the setup appears correct to me.
    Any other thoughts?
  • nguyendot
    You haven't posted how it is configured... We aren't going to guess for you.
    Main Surround -
  • insipid8
    insipid8 Posts: 4
    I've connected the SB3K as described in the instructions. I.E.
    1. I've connected the optical audio out of my TV (Sony KDL-46XBR6) to the input of the SB3K using the supplied optical cable.
    2. I get no audio out of the SB3k.
    3. I changed the sound output of the TV to go completely external disabling the internal tv speakers, still no sound from the SB3k.
    4. I do see the LED light coming from optical cable.
    5. I also went out to the store and purchased an analog to RCA cable and repeated the steps outlined above. No sound.
    I'm stuck. Help is appreciated.
    tonyb Posts: 33,072
    Do you mean the soundbar 3000 ?
    Did you try turning up the volume on the tv ?
    What model is the tv ?
    Also, did you view the tutorials on setting up the SB3 from the products page ?
  • insipid8
    insipid8 Posts: 4
    Do you mean the soundbar 3000 ? Yes
    Did you try turning up the volume on the tv ? Yes
    What model is the tv ? Sony KDL-46XBR6
    Also, did you view the tutorials on setting up the SB3 from the products page ? Yes
  • mikecowen
    mikecowen Posts: 1
    edited January 2011
    I have had exactly the same problem with the 3000 connecting to a Sony EX 500 46 inch. Symptoms are identical. TV is connected via HDMI cable to PVR/digital box. Soundbar is functional as I tested it by plugging it to a DVD player and the sound is great. I just got back from the electronics store....the salesmen there experienced the same problem..they could not get the 3000 to talk to the TV via the optical port. Is there a basic imcompatibilty??
