RTi10 opinions
Audioquest
These are currently on a Boxing Week sale for $500/pair. Just wondering how these rate as I haven't heard them.
HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
i dont know personally but google around and you'll see older postings im sure; until someone answers you on here.
RTi10s are excellent HT speakers. Gadabout has a pair matched with a B&K amp I think and they sound excellent for music. Most people will tell you the RTi series are too bright for music and I used to agree but Gadabouts setup changed my mind on that.
Synergy is the key.Speakers: SDA-1C (most all the goodies)
Great speakers! Owned a pair for a few years before gifting them to my daughter. Replaced them with ... the RTiA7s. No surprise there!Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
Synergy is the key.
Agreed! I tried several combos of receivers/amps until settling with what I have now - all in the name of improving musicality. HT sounded great with all combos. They sound far better for music than I ever thought they would.
I own a pair and drive them with a B&K amp. To me they are 9+ for HT and 7 for music. They can be bright with the right music and are very unforgiving of poorly recorded music, more so with the wrong source. I find keeping the volume down helps tame the brightness. I also agree that you need to power them properly to get the most out of them. With the amp in my signature they have much better bass and control. Looking at your signature I am guessing these would be used for HT most of the time. At that they excel and if they are new that is a good price.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I'll second that thought. Polk and B&K amps go well together.HT SYSTEM-
lsi 9's -
For me, the key was moving from Yamaha to H/K - tamed the brightness nicely. Music only sounds good to me when in "Direct" mode, though. This results in stronger mid-range (sounds wimpy when not in Direct mode) and tighter, fuller bottom end.
Hi, I bought a pair of RTi10s yesterday and I find the bass to be weak. do I need external amps with these speakers ? -
photocrazy wrote: »Hi, I bought a pair of RTi10s yesterday and I find the bass to be weak. do I need external amps with these speakers ?
First, what are you driving them with?
My RTi10s got a nice wake-up call with tha addition of a GFA-555 amp (ran from the preouts on a Denon 2106AVR) as well as using Signal Cable Ultra bi-wire speaker cables. Added a lot of bottom end as well as taming some of the brightness (which I honestly did not find too bad before at moderate volume levels anyway).
Also, make sure you have both sets of binding posts wired up, and/or the factory jumper in place... that could account for a lack of bass, and yes, it's happened before!So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
What are they hooked up to?
You probably have already done this - but check to see if your RTi10s are wired correctly and in-phase. Out of phase wiring would result in weak bass.
Placement might be another thing to check.
You could get more bass reinforcement by placing the speakers closer to the wall or corners (but this could result in 'tubbiness' and loss of bass accuracy - depending on your room acoustics).
Sounds like it. A lot of factors can affect bass - room size, placement, and inadequate amplification, to name a few. As I mentioned above, if you're using an AVR, "direct" mode will make a difference, too. You need to tell us more about your setup - 2-channel? 5.1/7.1 HT? Sub? Crossover?, etc...photocrazy wrote: »Hi, I bought a pair of RTi10s yesterday and I find the bass to be weak. do I need external amps with these speakers ? -
mdaudioguy wrote: »Sounds like it. A lot of factors can affect bass - room size, placement, and inadequate amplification, to name a few. As I mentioned above, if you're using an AVR, "direct" mode will make a difference, too. You need to tell us more about your setup - 2-channel? 5.1/7.1 HT? Sub? Crossover?, etc...
My receiver is pio vsx-1325 (vsx-33 clone). I have set it up for 2 channel. the speakers are set as "large" in Pio setup and have selected "no" for surrounds and sub. And I dont have any sub. -
I have a pair of these, and the bass is anything but weak. Sometimes I run them without my sub, aand the bass is clean and tight. I'm running mine with a separate amp. You should try that to see if there is a difference.Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
math wizard wrote: »I have a pair of these, and the bass is anything but weak. Sometimes I run them without my sub, aand the bass is clean and tight. I'm running mine with a separate amp. You should try that to see if there is a difference.
Lol..living in an appartment, i need to watch my sound levels. so, I am not sure I would need an external amp -
Asking someone else what a speaker sounds like, is like asking if coke is better than pepsi,, You need to listen to them your self, and base your purchase on what you like,,, Not what others think, Some people like white cadilacs,,some like black,,Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
photocrazy wrote: »Lol..living in an appartment, i need to watch my sound levels. so, I am not sure I would need an external amp
An amp doesn't necessarily make the speakers louder, just more dynamic,even at lower volumes,by feeding them what they need.HT SYSTEM-
lsi 9's -
I had to join,just for this topic..I have a pair of Rti10 along with a Onkyo 608,and ive been trying to figure out also how to get more bass out of them,i was even going to buy a new receiver to add a amp.But..i tried 1 more thing for the Rti10 and it worked.I Bi Amped them and used tone control to upped the bass and now they sound great! ..So im guessing the added seperate power to the Rti10 was needed..Samsung PN50B550 Plasma
Pioneer Elite SC-25
Pioneer Elite BDP-23FD
Adcom 7500 Amp-Panamax 4300 Conditioner
Polk RTi10's Fronts
Polk Csi A6 Center-Polk M60s rear Surrounds
Klipsch Synergy Sub-10 X2
Klipsch Synergy S-10 Premium back surround -
An early nominee for New Member of the Year! Great post, although I don't think this should preclude people from asking, or others from attempting to answer, but rather it's something that people need to keep in mind when they do ask. -
does bi-amping makes a difference ? -
photocrazy wrote: »does bi-amping makes a difference ?
You probably won't hear much of a difference biamping from just your AVR.
See if you can find an older B & K amp. You should be able to get one for $200 - $300. (Maybe less on Ebay) That's assuming your AVR has preouts.
You won't regret adding an amplifier to the RT110's
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
