Assembling the TT setup
  • steveinaz
    steveinaz Posts: 19,546
    edited December 2010
    Kimber Hero .5mtr cables, Clearaudio stylus and CF brush arrived. We're gettin' there...
    Now to get the wife to buy us a Plasma TV, so I can wall mount that sucka, and get my table on!
  • thsmith
    thsmith Posts: 6,082
    Steve, congrats on a fine setup. I have the same TT and love it. You may want to experiment with the mat. My finding matched the reviewes on that TT using the mat.
    The CA clamp others recommended is what I use as well. I believe H9 is the one that turned me on to it.
    I am waiting on my test LP in order to use the Fozgometer. Our TT allows for azimeth adjustments. We will see if it matters or not.
  • steveinaz
    I haven't bought the table yet, but it will likely be either the MMF-5.1 or the Marantz TT-15S1. If I do the MMF, and end up sticking with vinyl, I'll upgrade later.
    I'm pretty damn fussy (sensitive to) background noise---so I don't want to put all my eggs in one basket yet. I haven't owned a turntable since about 1986, so I'll need to readjust and decide.
  • vc69
    vc69 Posts: 2,500
    That Marantz is one sexy TT. I have been drooling over it since the MD catalog arrived a few months ago.
    What is everyone's opinion of the ClearAudio tables?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • thsmith
    steveinaz wrote: »
    Steve, I have LPs (used from half priced books) that are as quiet as any CD.
    After a good cleaning of course.
  • shack
    shack Posts: 11,154
    vc69 wrote: »
    I think generally Clearaudio is a little on the pricey side, but they are well engineered, very good looking (IMO) and just good tables. I think their cartridges are excellent...but again somewhat pricey. I have heard a few Clearaudio tables over the years and have always been impressed with the sound, build quality and looks.
  • hearingimpared
    hearingimpared Posts: 21,136
    shack wrote: »
    +1 every bit as good a table as some that cost lots more! . . . and purty too!
