A good Pre-Amp
PolkClyde
PolkClyde Posts: 662
edited December 2010 in Electronics
I'm looking for a good pre-Amp to buy,you guys have any suggestion?
PolkAudioClyde
Post edited by PolkClyde on
  • leroyjr1
    leroyjr1 Posts: 8,785
  • fbm211
    fbm211 Posts: 1,488
    Tube or SS
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • george daniel
    george daniel Posts: 12,096
    Tube or SS ?--If tubed,,might I suggest a 6SN7 based tube pre.
  • zingo
    zingo Posts: 11,258
    Preamp or pre/pro?
  • dcoil
    dcoil Posts: 153
    zingo wrote: »
    Preamp or pre/pro?
    I hate to jump in here (always trying to get educated :smile:), but can you explain the difference betwen the preamp and pre/pro?
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • vc69
    vc69 Posts: 2,500
    A preamp is a line or phono gain stage between source and amp. A pre/pro (usually for HT) does some other kind of processing (the "pro" part of pre/pro).
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • thsmith
    thsmith Posts: 6,082
    +1, then throw some treasure varients in for magic
  • PolkClyde
    thanks guys,for all your answers
    PolkAudioClyde
  • PolkClyde
    Lasareath wrote: »
    Just Good or Great? th
    Here is a great one:
    http://www.hometheaterhifi.com/volume_7_4/adcom-gfp-750-preamplifier-11-2000.html
    They go for around $600 to $700 used
    That's the one That I want,but it's hard to find.
    PolkAudioClyde
  • TroyD
    TroyD Posts: 13,124
    Melos SHA-1.
    BDT
  • fishbones
    fishbones Posts: 947
    I'm getting ready to list a Cary SLP-30 tube pre. It is a fantastic sounding pre - unless you have SDA's (reversed polarity needed at terminals).
    F1nut Posts: 51,903
    Clyde, haven't you been listening to Ted? You need tubes.
  • dorokusai
    dorokusai Posts: 25,576
    TroyD wrote: »
    Melos SHA-1.
    BDT
    The bar standard. Another solid would be a Anthem Pre2L.
    Polarity is up to the owner, even if designed in reverse and will work regardless of what is chosen.
  • fishbones
    dorokusai wrote: »
    Actually it cancels out the SDA effect. I tried it.
  • dorokusai
    Are we talking about SDA loudspeakers? Or just a preamplifier? I've not noticed any SDA cancellation personally but everyone's rig is different.
  • fishbones
    My Cary unit requires that you switch the polarity at the speaker terminals because of the circuitry design of the unit. Doing this on the 1C's cancelled the SDA effect. When I'd hook it up normal, then it sounded out of phase. Bypassing the unit and hooking directly to a CDP brought the SDA effect back instantly. So either way it doesn't work with the SDA's. But, it's an awesome sounding unit.
  • Lietuvis91
    Lietuvis91 Posts: 909
    vc69 wrote: »
    I'm actually glad someone asked this question, because I thought they were one and the same :redface:
    So is it safe to say that a pre would be mostly for 2ch listening and a pre/pro, as you said, is more HT focused? Just wanted to make sure understand correctly. :smile:
    BTW:Happy NEW YEAR EVERYBODY!
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • fishbones
    Lietuvis91 wrote: »
    Exactly!
  • Face
    Face Posts: 14,340
    Tubes are for tires. :tongue:
  • FTGV
    FTGV Posts: 3,650
    Face wrote: »
    LOL,or target practise.
  • Lietuvis91
    fishbones wrote: »
    Exactly!
    Thank you, sir!
  • PolkClyde
    F1nut,I have the carvers silver 7t mono amps. would tube(s) pre-Amp be a good choice with the carvers? I'm looking at The Adcom GFP- 750,that's a SS amp,right?
    PolkAudioClyde
  • FTGV
    FTGV Posts: 3,650
    PolkClyde wrote: »
    Great preamp and yes it is SS using only a pair of Mosfets for it's active gain stage.It's essenially an economy version of Pass's Aleph P unit.
    +1 on the GFP-750, but you should also listen to some of the others suggested above. I like doro's Anthem choice as well...a very sweet sounding pre!
    Good Luck!
    cnh
  • jimmydep
    jimmydep Posts: 1,305
    cnh wrote: »
    Good Luck!
    cnh
    I agree, I've heard both and the Anthem is a step up from the 750, especially in mid range detail.
    Ask Lasareath, as he has had both of these in his system.
  • Audioquest
    Audioquest Posts: 104
    PolkClyde wrote: »
    That would be a great choice. I used to have a pair of that same amp and thought they were really strident and bright with no character at all. A nice tube amp might be the ticket. The Adcom is SS not tube. Find a used Sonic Frontiers SFL-1 sig, which has a nice liquid sound and lots of detail with the right tube. They are also relatively inexpensive and hold their value in case you don't like it. There are other good/better ones as well, but most that equal or better are more $$$.
    HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
    2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
  • george daniel
    I would look for a 6SN7 tubed pre,,like a Rogue such a Carl has,,I actually listened to one with a pair of 9T's and it really matched up very well and provided a smoother sound and a great soundstage.Good luck.
  • PolkClyde
    Have you guys heard Ted's rig? wow, every time I go to his house it sounds better and better, with the kind of music we listen too.The sound is clear with a lot of detail,even the bass is good now(without a sub). my musical taste is from James Taylor to James Brown.Ted's taste is a little more laid back then mine.he has introduce me to a lot of good music.I love country music but I also like to get funky sometimes... GOOD GOD.
    PolkAudioClyde
  • PolkClyde
    I also like to add,you guys ears are more educated than mine.right now I can't hear a difference between SS or tubes.they all sounds great to me.I know this is debatable,but the most important component in the system,IMO are the Speakers. :) thanks guys,maybe ted will sell me his Tube pre-amp, not likely.
    PolkAudioClyde
