Need your help guys
hookmeup
hookmeup Posts: 4
edited December 2010 in Speakers
So the saga begins nothing good is cheap or easy, so help me if you can of corse I am going to by polk,,,,, the question is what should I buy for a new system I am going to buy a mitsubishi 82 inch tv and want to start getting together a polk system the room it is going in is open ceiling 2 story about 25 long and 15 wide,I am looking at the lsi 25 series what do you recomend for aditional speakers and would you run 4 lsi 25 be better than the rear lsi fx soround sound also what receiver would I use help help help oh and who has the best prices thanks
Post edited by hookmeup on
    F1nut Posts: 51,788
    You should wait for the new LSiM series to arrive. Either way, you'll want more than an AVR to drive them with.
  • hookmeup
    hookmeup Posts: 4
    are you saying 4 towers is the way to go
  • hookmeup
    hookmeup Posts: 4
    when does the new stuff come out and do you no what the differance would be
    txcoastal1 Posts: 13,513
    I think that was misleading your towers and center for the fronts and LSI9's for the rears...FX's in a more enclosed room was his preferences
    but as F1 commented the new LSiM's will be here shortly after CES2011 hopefully
    hookmeup wrote: »
    Most are not quite sure....but we are excited like kids at Xmas
    tonyb Posts: 33,072
    Regardless of when the new stuff comes out, if you choose any of the LSI speakers, new or old, you need a receiver with preouts and an amp, capable of driving all of the lsi speakers.
  • angelsfann02
    angelsfann02 Posts: 589
    hookmeup wrote: »
    Welcome to the forum. What is your budget? If you want to run Polk Lsi speakers, external amplification is almost a must. So you need to factor this into your budget. There are plenty of Polk speakers that sound great for hometheater, and dont require anything other than a good receiver.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • hookmeup
    hookmeup Posts: 4
    10,000 is the budget
