Need your help guys
hookmeup
hookmeup Posts: 4
edited December 2010 in Speakers
So the saga begins nothing good is cheap or easy, so help me if you can of corse I am going to by polk,,,,, the question is what should I buy for a new system I am going to buy a mitsubishi 82 inch tv and want to start getting together a polk system the room it is going in is open ceiling 2 story about 25 long and 15 wide,I am looking at the lsi 25 series what do you recomend for aditional speakers and would you run 4 lsi 25 be better than the rear lsi fx soround sound also what receiver would I use help help help oh and who has the best prices thanks
Post edited by hookmeup on
    F1nut Posts: 51,945
    You should wait for the new LSiM series to arrive. Either way, you'll want more than an AVR to drive them with.
  • hookmeup
    hookmeup Posts: 4
    are you saying 4 towers is the way to go
  • hookmeup
    hookmeup Posts: 4
    when does the new stuff come out and do you no what the differance would be
    txcoastal1 Posts: 13,519
    I think that was misleading your towers and center for the fronts and LSI9's for the rears...FX's in a more enclosed room was his preferences
    but as F1 commented the new LSiM's will be here shortly after CES2011 hopefully
    hookmeup wrote: »
    Most are not quite sure....but we are excited like kids at Xmas
    Regardless of when the new stuff comes out, if you choose any of the LSI speakers, new or old, you need a receiver with preouts and an amp, capable of driving all of the lsi speakers.
  • angelsfann02
    angelsfann02 Posts: 589
    hookmeup wrote: »
    Welcome to the forum. What is your budget? If you want to run Polk Lsi speakers, external amplification is almost a must. So you need to factor this into your budget. There are plenty of Polk speakers that sound great for hometheater, and dont require anything other than a good receiver.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • hookmeup
    hookmeup Posts: 4
    10,000 is the budget
