New Here!
bigdsw2001
Im new to the Ht thing and i was wondering if anyone knows any good web sites that shows wiring diagrams? Right now i have a Panasonic 47 PT-47WX53 hd tv, a Yamaha HTR-6540 receiver, an HD cable box, and all polk speakers.. the speakers i know how to hook up and stuff its just the wiring. i dont want to spend alot of money on cables i dont need hooking up the receiver. ive heard i dont hook anything up to the reciever except the audio and thats all. Then ive heard you do hook up everything through it. i will be getting a dvd and cd player very soon too. any help will be greatly appreciated.
NICE TO MEET YOU ALL!
Darien
Darien
Post edited by bigdsw2001 on
CD Outs (on the cd player) to CD ins on the receiver
DVD outs (on the dvd player) to the dvd ins on the receiver
Tape outs (on the tape player) to the tape ins on the receiver
VCR outs (on the vcr) to vcr ins on the receiver
the list goes on
Speaker wires, black to black, red to red
fronts to mains
surrounds to surrounds
center to center
LFE channel OUT to input on sub- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Go ahead and hook everything up to the receiver, then the video output on the reciever goes to the TV.
People will tell you to hook the video straight from your DVD to your TV, and your audio to the receiver. The reason is that when you switch video (or audio for that matter) you actually lose some of the quality due to the video switch circuit in your receiver. But while that may be true, in todays revceivers you would be hard pressed to tell the difference (which might require a VERY high end TV to actually see any difference at all. It is much better in my opinion to just hook everything into the receiver and let it do its job. Besides, the video loss is probably only dectable if your using test equipment.
Howie -
Thanks alot for your help. But my receiver only has one optical and one digital Coax. So when i have those do i still need rca's? right now i have my Cox HD box plugged right into my tv now. the red, blue, and green, of the box right into the tv, and of course the audio outs into the tv also. what im really messed up about is if i have an optical cable do i even need the digital audio out component or the regular red, white audio out cable? im sorry guys
im learning slowly. -
The best video is component---- red, blue,green
The second best video is---- svideo
The lowest video is yellow
The best sound digital coax
The second best sound is optical--toslink
The lowest hook up for sound is analog - red &white
