Help
i know this is going to sound like a rookie question, but here goes.
i just replaced my rt10's with new tsi400's. the only thing i did was unhook the old speakers, and hook up the new ones.
the problem is, now i have no sound coming out of them. i do NOT have them bi-wired, and i can't imagine what the problem is.
if anyone can help out, please do.
thanks.........kevin
50" samsung dlp
receiver... pioneer elite vsx72txv
front... polk tsi400's
rear surrounds... polk tsi100's
center... polk csi3
subs... psw150..... 2 of them.
surrounds.....polk owm3's
center... polk csi3
So your rt10's were working when disconnected? can you hook them back up to insure the system is still functioning, then we can eliminate those components. If you had something else to drive the Tsi's to test them it would help alsoSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Check the receiver, is the A speaker on?
Hook the old speakers back up.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
good guess. ^ i must have hit the speaker button earlier when i was cleaning everything. as soon as i posted i figured it out. boy do i feel like an idiot.
anyways, thanks for the responses.50" samsung dlp
center... polk csi3
surrounds.....polk owm3's -
I did the same thing once, drove me nutty for about ten minutes. The old advice to start with the basics during troubleshooting came to mind. I remember my IT friend always starting with is it plugged in, did you turn it on, etc... but half the time that fixed it.
