Subwoofer cable
mbond24
mbond24 Posts: 17
A few weeks ago while shopping for a good sub cable, a rep at Best Buy told me that I can use regular coax cable with an F connector at (adaptor) each end as a very good sub cable. Has anyone used this kind of setup before?
Post edited by mbond24 on
  • nguyendot
    nguyendot Posts: 3,594
    edited December 2010
    You can, and it'll probably work. Make sure one end has the ground disconnected (the end attached to the sub).
    It's cheaper just to buy a sub cable from monoprice, honestly.
    Main Surround -
  • Beta
    Beta Posts: 267
    Audio Advisor sells a pretty good priced Audioquest sub cable.
    http://www.audioadvisor.com/prodinfo.asp?number=AQBTIISUB
  • mbond24
    mbond24 Posts: 17
    Thanks for the advice guys. Now I realizied I need to run about 10ft of wire in-wall. Would coax for the in-wall portion be good along with the standard sub cable at each connection (rec & sub)?
    tonyb Posts: 33,072
    Are you talking speaker wire in addition to a sub cable ? Speaker wire is not coaxle, or did I not understand your question correctly ?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    mbond24 wrote: »
    I would think whichever cable you pick - stick with one type end to end for in wall, sub, and avr patch cables.
  • codyc1ark
    codyc1ark Posts: 2,537
    I recently upgraded mine from some no name RCA to a Monoprice cable, with a Y adapter. I know there are much better cables then the MP's out there, but I can tell you it did make a difference from the no name cable, with no Y adapter. I belive both the adapter and cable shipped was around $16.00 to my door. Check them out - www.monoprice.com - Hope that helps.
  • djperez81
    djperez81 Posts: 388
    monopri
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • djperez81
    +1 for monoprice, i recently purchased some cables from them and am very pleased with the cables and you cant beat the price.
    -Jimi Hendrix
  • duukanu
    duukanu Posts: 4
    Hi I am setting up a vintage set with an RM1000 sub and rw3000 satelite speakers, I have not been able to find wiring inst. The sub has only rt lt in jacks, are the tree speakers wired individually?
  • Mattcc22
    Mattcc22 Posts: 21
    I use Monoprice sub cable. Works perfectly and I see no problem running it in-wall
  • acmf74
    acmf74 Posts: 937
    would there be any audible difference in a Mono-price cable vs a Blue jeans one sub-woofer cable?
