RT55 Problem......
shawn474
shawn474 Posts: 3,052
edited December 2010 in Speakers
I have a pair of RT55's that I am using as my front stage. They sound great, but recently I noticed the left front tweeter was not working. I ordered a pair of new tweeters and still doesn't work on the left front. So i am thinking the crossover might be bad.
1.) How hard are the crosovers to replace?
2.) Does anyone have on lying around that they'd be willing to sell me or know where I can get one?
3.) Considering the tweeter is new, is there anything else it could be but the crossover? (the two woofers work fine)
Thanks in advance,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
    Tony M Posts: 11,989
    Is the jumper plate still on ?
  • shawn474
    Actually, it is not. I just looked qand never even thought twice about it. What should i do to recreate a jumper?
    Thanks tony,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Just use a short piece of speaker wire to link the upper and lower binding posts. You can also remove enough of the speaker wire's insulation to allow the signal to connect the upper and lower posts. Anything that gets the signal to both places will be fine.
    Regards, Ken
  • shawn474
    Thanks Tony and Ken. I am glad it was something that simple. I feel like an a$$ for not looking at that before, but thanks again.
    Take care and Happy Holidays,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    Worked like a charm; thanks again guys.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • [Deleted User]
    No problem, glad you've got tunes for Santa!
    That's great. I wish all our problems were that easy to fix.
    I had a front tower popping one time when the music would hit hard.
    Oh no, an amp. a woofer the dvd player....all went through my head. All it was, was a speaker wire that was loose on the popping speaker. It was just making contact at the terminal so it worked until a loud thump or something. It would lose connection and then re-touch and bam...
    easy fixes sometimes.
    Now when my Sunfire system made succesive pops and then a hummmmm, that was the other end of our worry scale. 400.00 repair...:-(
    Merry Christmas to you. I'm glad it was simple.
