Onkyo HT-RC270 and Monitor 70s, what should I expect?
djjaeger82
djjaeger82 Posts: 6
edited December 2010 in Electronics
Tonight I just picked up an Onkyo HT-RC270 for $425 from Amazon during a Lightning deal (couldn't pass it up). For those not familiar with the RC series they're very similar to NR models (in this case TX-NR708 except minus the RS232, 12V trigger, and one less HDMI input). I've been leaning towards onkyos for quite some time now based on the MultiEQ and Audyssey DSX options for front wides or front heights since my apartment is not suited well for a true 7.1 setup. I've got a pair of monitor70s as fronts, a CS2 center, and 4 monitor 40s for surround/wides/heights. (Currently i'm running off of an old kenwood VR-309 which has no HDMI capability, and no DTS master audio or Dolby TrueHD support, so i'm definitely in need of an upgrade)
Tonight I read in a few forums for this receiver that it actually doesn't pair well polks, in fact many were claiming that polks and onkyos don't go together well in general. Instead many were recommending pioneer receivers to go with the polk monitor series. Anyone here have an HT-RC270 (or similar model like TX-NR707, TX-NR808, TX-NR1008) and polk monitors? I'm curious what real polk folks think!! Hopefully I won't regret this quick purchase tonight, but the deal was so good and I had limited time to jump on it before finishing my research.
Thanks in advance!
Dan
Post edited by djjaeger82 on
    tonyb Posts: 33,072
    They match up fine with Polks. Plenty of people here run them together with good results. Don't worry,be happy.
    nooshinjohn Posts: 25,933
    Congrats on the score. As Tony said... Kick back and enjoy the music, or movies.
    tonyb Posts: 33,072
    Get yourself a subwoofer while your at it. What else are you running ? DVD,BDP,CDP ?
  • TrashyTrucker
    TrashyTrucker Posts: 225
    tonyb wrote: »
    +1 what he said! Enjoy your new audio adventure!
    Merry Christmas' USA
    Matt :biggrin:
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • djjaeger82
    djjaeger82 Posts: 6
    Thanks guys, your feedback is definitely easing my worries. I also have a polk PSW-505 subwoofer which I really enjoy. I used to have an old boomy Sony WM40 sub, and some old kenwood that came with an HTIB 10 years ago, and I have to say I finally understand what people mean about a tight deep bass from a sub when it comes to music. I mostly listen to blurays and HDTV but occasionally i'll use some CD audio.
    Thanks and happy holidays!
  • boomerfss
    boomerfss Posts: 125
    We have similar set-ups. I have the HT-RC180 (110watts per channel). I noticed a big difference after about 2 months (break-in period?) with the Polks. They are starting to sound fantastic.
    Cheers.
    Onkyo HTRC 180
    Polk Monitor 70 Series 2 Fronts
    Polk CSi A6 Center
    Polk PSW505 Sub Woofer
    Polk Monitor 60 Series 2 Surrounds.
    Harman Kardon HTSK18 Back Ceiling Mounted
    PS3 Xbox
    Who says Onkyo and Polk don't go together? That's news to me! My bedroom system is an Onkyo 604, a pair of Rti-4s and an 8" sub, 32" LCD, and a Toshiba HD-DVD as the DVD player. And RTIs are generally considered bright--but they're OK in this set up! The main system is an Onkyo TXSR-805 and M70s, CS2, and M30s, 12" 50lb 300 watt RMS sub (-25hz low). Pretty impressive in a medium sized room on the Sony ES BDP bitstreaming HD audio to the Onkyo. The important thing about M70 placement is to make sure that you're not too far from the adjacent walls and the listening position forms that desired TRIANGLE with the listener.
    You're fine. Run the Audyssey and enjoy some films!
    cnh
  • dorokusai
    dorokusai Posts: 25,576
    I think Onkyo and Polk are a great match.
  • B Run
    B Run Posts: 1,888
    djjaeger82 wrote: »
    I use that same Sony in my living room setup and I noticed the same thing until I modified it, it was a night and day improvement.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    djjaeger82 wrote: »
    Tonight I read in a few forums for this receiver that it actually doesn't pair well polks, in fact many were claiming that polks and onkyos don't go together well in general. Dan
    Well, the good news Dan is that at least you now know who (on the other forums) is full of malarkey. :smile:
    Running an Onkyo AVR (backup) with my Polks, bought a full 7.1 Onkyo/Polk setup for my daughter and son-in-law (and I wouldn't stick my granddaughter with a bad rig :smile:), and have an Insignia (:eek:) AVR running a Polk Soundbar downstairs on the rig my sons use for gaming. That Insignia R5101 ... something or other ... is actually made by Onkyo for BestBuy and is actually an Onkyo 508.
    So .... as others have said ... ENJOY ! You did good ! :biggrin:
  • djjaeger82
    djjaeger82 Posts: 6
    Thanks again for everyones comments, i definitely think those guys had no clue what they were talking about. Only thing i'm wondering is if I should have saved up for an RC180 or something thats a little beefier. (But then again at least I have the preouts so I can always step up to some external amps some day when I get a bigger house/apt/room). Also, any predictions about CES 2011 for new receivers? What new features might be on the horizon for 2011? (One place I read streaming video via network, and built in wifi perhaps...)
  • polkfarmboy
    polkfarmboy Posts: 5,703
    djjaeger82 wrote: »
    What you should have done it bought my pioneer vsx01thx for $350 shipped lol
    Dont worry what others say about onkyo..I had an onkyo 607 hooked up to martin logans and sounded awesome
    Onkyo makes some great sounding avr's and many people are just too fussy or expect miracles from a budger avr
    My onkyo and polk rti was amazing and the monitors are slighly warmer than the rti so it will sound great...just pop in a blue ray and youl find out what your onkyo was made for.......doing great movies
  • djperez81
    djperez81 Posts: 388
    i have 2 different onkyo and polk setups both sound great.......whatever forum you read that on are full of it. Dont sweat it you should be very pleased with your purchase.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Lietuvis91
    Lietuvis91 Posts: 909
    You should be fine with that setup, I really like my onkyo with polks in my HT setup. I will agree with someones statement above that you will want either a sub or an amp to run these. I would suggest a good sub to offload the lower frequencies or an amp to run them well in large/full mode.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
