PSW202 fuse is blowing
Does anyone know if the fuse for the PSw202 is a fast acting or slow blow fuse? Any suggestion to what could cause it to blow. I replace it and it blows right away.
thx
J
thx
J
I believe it is a time lag fuse which will react slower than a standard (instantaneous) fuse but faster than a slo-blo.
With that sub-woofer if the fuse blows the problem is with the bass amplifier. Check with Polk's CS on Monday at 1-800-377-7655 they'll be able to help you out.
Regards, Ken -
