Resistor question
VR3
If the stock xover used a cheap ol 10watt resistor, is it safe to assume you can jump to a 20-25 watt without issue?
Post edited by VR3 on
Yes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Going from 10W to 20W or 25W is a big jump. If possible, look for the same wattage or something closer like 12W, 15W first as substitute before going with 20W or 25W ones.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
That's an awful big change in resistance Trey. What, if you don't mind me asking, are these going into?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
This is in the woofer network - the rest of the network uses 5 watts, then there is a 36ohm 10 watt in the woofer - I assumed this could be changed to a 25watt based on past convos with Face, correct?
Its a Def Tech CLR1000- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I found a 20watt 33ohm 2%
vs. the stock 10watt, 36 ohm 10%
Should be ok right?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Higher wattage resistors can be more inductive, but I wouldn't worry about it in a woofer shunt.
FYI, Mills makes a 33ohm, 12w resistor: http://soniccraft.com/mills_resistors.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Damn, don't I feel like the donkey. I thought you were talking about the ohms. Reading it again, I see you were referring to watts. Yes, it will work.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Cool
I am sticking with PartsConnexion on this one ---
We are hot rodding the BP20 and CLR1000 he bought -- Auricaps on the tweeters, mills resistors throughout - that 36 ohm I am going to throw a Mundorf M 20 watt - woofer networks just going to use Solen to keep it simple.
I really liked the sound of the Auricaps on the DT tweeters so I wanted to use those for him and they were the only ones that had them in stock. I wanted it all to ship from the same place.
These are not my speakers so I dont really "care" what specific parts go where and he wont hear the initial difference in parts like I would.
So cool
Thanks everyone!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The power rating on a resistor does not coincide with the resistance rating.
