Resistor question
VR3
VR3 Posts: 29,583
edited December 2010 in DIY, Mods & Tweaks
If the stock xover used a cheap ol 10watt resistor, is it safe to assume you can jump to a 20-25 watt without issue?
Post edited by VR3 on
  • ben62670
    ben62670 Posts: 15,969
    Yes.
    Ben
  • megasat16
    megasat16 Posts: 3,521
    Going from 10W to 20W or 25W is a big jump. If possible, look for the same wattage or something closer like 12W, 15W first as substitute before going with 20W or 25W ones.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    treitz3 Posts: 20,166
    That's an awful big change in resistance Trey. What, if you don't mind me asking, are these going into?
    VR3 Posts: 29,583
    This is in the woofer network - the rest of the network uses 5 watts, then there is a 36ohm 10 watt in the woofer - I assumed this could be changed to a 25watt based on past convos with Face, correct?
    Its a Def Tech CLR1000
    VR3 Posts: 29,583
    I found a 20watt 33ohm 2%
    vs. the stock 10watt, 36 ohm 10%
    Should be ok right?
  • Face
    Face Posts: 14,340
    Higher wattage resistors can be more inductive, but I wouldn't worry about it in a woofer shunt.
    FYI, Mills makes a 33ohm, 12w resistor: http://soniccraft.com/mills_resistors.htm
    Damn, don't I feel like the donkey. I thought you were talking about the ohms. Reading it again, I see you were referring to watts. Yes, it will work.
    VR3 Posts: 29,583
    Cool
    I am sticking with PartsConnexion on this one ---
    We are hot rodding the BP20 and CLR1000 he bought -- Auricaps on the tweeters, mills resistors throughout - that 36 ohm I am going to throw a Mundorf M 20 watt - woofer networks just going to use Solen to keep it simple.
    I really liked the sound of the Auricaps on the DT tweeters so I wanted to use those for him and they were the only ones that had them in stock. I wanted it all to ship from the same place.
    These are not my speakers so I dont really "care" what specific parts go where and he wont hear the initial difference in parts like I would.
    So cool
    Thanks everyone!
  • zingo
    zingo Posts: 11,258
    The power rating on a resistor does not coincide with the resistance rating.
