Need Help Christmas Blues
eliminator1970
eliminator1970 Posts: 77
So I come home from work to find my system moved to a new room, and told the one SDA1c will not work. After the grinch in me came and went I went about checking all the connections and all seemed correct. Then I disconnected speaker wire and re-installed, and still nothing. So I pulled everything apart and re hooked everything back up. Now I can get some sounds while the interconnect is connected. Mainly the right channel sounds like only the highs are playing while the left is muted lows. Not sure where to go from here. I have had amp (Adcom GfA 555 and pre-amp GFP-1A) for 25 years without a problem. ANy ideas?
Post edited by eliminator1970 on
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited December 2010
    First things first. Has the person who moved the system been properly dealt with?
    Do you have another receiver or amp you can connect the speakers to? Have you tried with only one speaker at a time, no interconnect?
    F1nut Posts: 51,917
    ANy ideas?
    File for a divorce.
  • ben62670
    ben62670 Posts: 15,969
    Something is wrong with your left channel output. Try wiring it so that the right speaker output is going to your left speaker.
    Ben
    Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Nice your system moved without your knowledge. Sweat and now doesn't work.... How do you even know if the proper powering off was done prior or not.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • danger boy
    danger boy Posts: 15,722
    So I come home from work to find my system moved to a new room, and told the one SDA1c will not work. ANy ideas?
    first off.. someone must be strong.. 1C's are no light speaker.. secondly, no one but me touches my system, esp not move it for petes sakes. :confused:
    PolkFest 2012, who's going>?
