Need Help Christmas Blues
eliminator1970
So I come home from work to find my system moved to a new room, and told the one SDA1c will not work. After the grinch in me came and went I went about checking all the connections and all seemed correct. Then I disconnected speaker wire and re-installed, and still nothing. So I pulled everything apart and re hooked everything back up. Now I can get some sounds while the interconnect is connected. Mainly the right channel sounds like only the highs are playing while the left is muted lows. Not sure where to go from here. I have had amp (Adcom GfA 555 and pre-amp GFP-1A) for 25 years without a problem. ANy ideas?
First things first. Has the person who moved the system been properly dealt with?
Do you have another receiver or amp you can connect the speakers to? Have you tried with only one speaker at a time, no interconnect? -
ANy ideas?
File for a divorce. -
Something is wrong with your left channel output. Try wiring it so that the right speaker output is going to your left speaker.
Ben -
Nice your system moved without your knowledge. Sweat and now doesn't work.... How do you even know if the proper powering off was done prior or not.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
eliminator1970 wrote: »So I come home from work to find my system moved to a new room, and told the one SDA1c will not work. ANy ideas?
first off.. someone must be strong.. 1C's are no light speaker.. secondly, no one but me touches my system, esp not move it for petes sakes.
PolkFest 2012, who's going>?
