Digital Cable preference
pearsall001
pearsall001 Posts: 5,291
edited December 2010 in 2 Channel Audio
What digital cable are you guys using & what are the qualities you like about it. Which ones have you used & what made you choose the current one you're using. I'm currently using a Creative Cable Concepts "Green Hornet". I like the cable a lot but I'm just itching to try another one between my DAC & source.
Post edited by pearsall001 on
  • nhhiep
    nhhiep Posts: 877
    it's digital. so I use whatever cheapest and work
  • steveinaz
    steveinaz Posts: 19,545
    In the inexpensive category, I really like the nuetrality of Blue Jeans Belden 1694A. Excellent cable, at any price.
    I also like and use DH Labs D-75.
    The DH Labs adds just a touch more sweetness to the "tell-it-like-it-is" Belden. Seriously, the belden is a seriously underrated cable, that performs like crazy. $23 bucks!
  • steveinaz
    Sometimes I think the Belden is better than the DH Labs....at any rate, it's splitting hairs.
  • thsmith
    thsmith Posts: 6,082
    I have tried a few but the Kimber Kable D-60 is by far the best I have heard. There is one here on the flea market for sell.
    Get your read on and you might be surprised what a great cable it is.
  • BlueFox
    BlueFox Posts: 15,251
    I was using the Omega-Mikro Zephyr, but recently upgraded to the MIT Magnum. Both are great, and offer clearer more detailed sound than the stock Wadia iTransport cable. However, the MIT digital is just like their analog cables. The soundstage literally expanded, and became more precise, with the MIT.
  • pearsall001
    thsmith wrote: »
    You're right, the D-60 was an awesome cable until Chris Sommovigo outdid himself with his newer design...the i2Digital X-60 & the Stereovox reference XV-Ultra.
  • FTGV
    FTGV Posts: 3,650
    Canare LS61 with their 75ohm RCA cons.
  • dorokusai
    dorokusai Posts: 25,576
    MIT cables.
  • Ricardo
    Ricardo Posts: 10,636
    Is wireless streaming digital? Then no cable here.
    How cool is that.
    SOPA
    heiney9 Posts: 25,432
    Signal and thinking about getting a MIT digital cable (to match my other IC's).
    Ricardo wrote: »
    No, how do you get the analog from the streamer to your pre-amp? Magic smoke :tongue:
  • Ricardo
    heiney9 wrote: »
    I know. digital cable to the DAC. But is the wireless from the router to the SQB a digital signal?
    SOPA
  • fbm211
    fbm211 Posts: 1,488
    Acoustic Zen MC2 AES/EBU
    Prophecy Cryo-Silver™ Reference i2s Digital Link cable
    The DH labs D-75 and D-110 are great bang for the buck cables.Ive owned both but have moved up the chain slowly over the last few years.I plan to have the Prophecy Cryo-Silver™ Reference AES/EBU Digital Link cable soon to replace the MC2.And you can get good deals at revelation audio labs if you ask.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Systems
    Systems Posts: 14,873
    I use Auricle Audio Signature digital in 2 of my systems.
    They are the best buy in audio IMHO.
    I have a MITerminator 2 in a third system that sounds really good.
    I would like to try a Zen MC2 but cannot see spending that much on 1 cable.
    I also keep an Apogee Wyed eye, and Canare just in case.
    Testing
    Testing
    Testing
  • zingo
    zingo Posts: 11,258
    The DH Labs D-75 is my new standard in digital coax; simply great.
  • megasat16
    megasat16 Posts: 3,521
    All Monoprice Premium for Digital. I know I am cheap. But hey, it's Digital, u know?
    Unless it's for Analog rig, I don't want to spend more than 5 bucks for the digital cables.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Beta
    Beta Posts: 267
    Cardas lightning. Great digital cable. Since moved to the MIT Magnum because of the wonderful experience I have had with MIT's ICs and speaker cable. Once again, extremely happy with another MIT acquisition.
  • bikerboy
    bikerboy Posts: 1,231
    Its still wire! It seems the DH Labs is a fav. I like it also.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • pearsall001
    I just ordered a Black Cat Veloce digital cable from The Cable Company. I'll be doing an A/B with my Creative Cable Concepts "Green Hornet".
    The Black Cat Company is a subdivision of Stereolab cables. The design is still done by Chris Sommovigo. This should be interesting. Chris is well known for his digital cable innovations starting when Kimber asked him to design a digital cable for them back in the 90's. I believe the cable is still in production from Kimber. He has updated his design over the years & the Veloce is one of his newest.
  • acmf74
    acmf74 Posts: 937
    For all my digital connections I use Blue Jeans and am VERY pleased with them. Not too long ago I swapped the one from my CDP to AVR and used a AQ VSB-1 cable. After some time of careful listening cable I couldn't tell the difference. With that I moved back to the Blue Jeans cable.
    http://www.bluejeanscable.com/store/digital-audio/
    Excellent people to deal with too.
  • steveinaz
    The Belden 1694A (ref above) is a very good cable, and yes, the cheesey orange jackets can be removed. I decided to try it when I noted that this is the cable Benchmark recommends and sells for the DAC1 variants.
