LSiC Problem
praedet
praedet Posts: 314
edited January 2011 in Troubleshooting
All right folks, I am trying to figure out what happened to me LSiC...
Last night during the Toy Story 3 BR, listening at moderate to low volumes, there was VERY noticeable distortion during some very specific scenes. It was only there for those scenes.
The full background is that this was the original LSiC that I sent to the Skiing Ninja for cross-over mod work. It has an external cross-over. It is powered by an Outlaw 7700. I have not had any problems with it up to now. (Well, the last problem was due to the new inductor, which is now external, so that doesn't count ;))
I am thinking it is either the low-end driver, or the portion of the cross-over dealing with said driver. THe reason I say this is I would think the mid-range and tweeter would be used almost 100% of the time on a center, but the low guy would only come in every so often. I think have it cross-over at 100 hz in the preamp.
So, how do I track down what is wrong, I am kind of new to the debugging a speaker problem scene... ;)
Ted
HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure ;)
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
Post edited by praedet on
    treitz3 Posts: 20,083
    edited December 2010
    Hello, Ted. Switch speakers only and see if it follows. Do not switch x-overs.
  • praedet
    praedet Posts: 314
    How? The wires from the cross-over to the speaker are soldered in. Are you saying inside the speakers, put the mid-driver wires on the low and vice-versa?
    Or, move an LSi9 to LSiC duty...
    praedet wrote: »
    Just move one of the two mains to the center channel. Tell me what happens.
  • praedet
    praedet Posts: 314
    ^^^Got it, unexpected things took me away the next morning after this post, but I will try this as soon as I get back...
    How much is one of the midrange/woofers on the LSi from Polk?
    Dunno, you'll have to call and find out.
  • praedet
    praedet Posts: 314
    edited January 2011
    Hmmm, problem is the BDP-83, go figure!
  • praedet
    praedet Posts: 314
    edited January 2011
    ^^^Reported
    edited January 2011
    You reported yourself? Oh, the humanity. :eek:
    J/K, I know it was SPAM.
  • camtah
    camtah Posts: 128
    edited January 2011
    praedet wrote: »
    So what was the problem with the BDP-83?
  • praedet
    praedet Posts: 314
    edited January 2011
    Basically, it can't handle the 7.1 DTS-MA track yet. Oppo is working a firmware fix for it...
