New guy with SDA2B mod questions
cheezer
cheezer Posts: 4
edited December 2010 in Vintage Speakers
Hi all. A while back I picked up a pair of these at a garage sale for $50. they had a frozen woofer,and were missing the interconnect cable. Thanks to this forum I was able to bring them up to speed with a polk replacement,and a DIY interconnect. Pretty nice speaks for $110.
I then recapped with a combo of Solens for the lows,and a clairity cap PX for the HF,and used a Mundorf resistor. Much better,and that brings up my question. I'd like to go the RDO 198 TL route,but clairity caps only offers a 5.6 in the px range,and I'd like to stay in that range.
Close enough,or use a .2 clairity SA cap with it? Also I didn't pull the 750 mica,when I do,do I use a jumper or just pull it?
Thanks for any info,and for all the info I've culled from this forum.
John
Post edited by cheezer on
  • inspiredsports
    inspiredsports Posts: 5,502
    Hi John,
    Welcome to CP. I wonder if Clarity caps can be custom valued?
    As you probably read, mAny of us buy Sonicaps from Sonic Craft and they custom value for about a buck fifty a cap. Clarity caps are sweet and it would be great if you could get one spot-on 5.8uf.
    I think percentagewise 5.6uf is well within the parameters to replace a 5.8uf, but 5.8 is what Polk found to be ideal. I don't think it would be a good idea to bypass it with a .2uf. Even though capacitance is additive, the .2 becomes the path of least resistance and processes a disproportionate amount of the signal so my guess is the sound quality through a 5.6 + .2 would be different that from a proper 5.8 or a substituted 5.6 alone.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    george daniel Posts: 12,096
    and,, you can just remove the silver mica,, no need for it since you are using better caps
  • Disc Jockey
    Disc Jockey Posts: 1,013
    At 5% tolerance the 5.6 px will be fine, definitely don't add the .2. It will just act as a bypass cap and you don't want that. Enjoy, and welcome to CP!
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • helipilotdoug
    helipilotdoug Posts: 1,230
    The tl upgrade is really worth it! Go with the custom built Sonicap 5.8.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • inspiredsports
    There is a lot of healthy interest in other brand caps.
    I think the way to put it is that Sonicaps give you 95-97% of what is possible on a beer budget, but there are some champagne caps out there that approach 99.9%
    Clarity Caps (MR MKP) are generally considered to be a step up from Sonicaps, albeit at a slightly higher cost.
    Consider the Mundorf Supreme Silver Gold Oils if you really want to go there.
    NAD SS rigs w/mods
    GIK panels
  • cheezer
    cheezer Posts: 4
    Thanks for the info guys. Guess it's time to start shopping. And I am on a beer budget here:biggrin:.Looks like I'll be into them for about $300 total-not bad. thanks again-John
