New guy with SDA2B mod questions
cheezer
Hi all. A while back I picked up a pair of these at a garage sale for $50. they had a frozen woofer,and were missing the interconnect cable. Thanks to this forum I was able to bring them up to speed with a polk replacement,and a DIY interconnect. Pretty nice speaks for $110.
I then recapped with a combo of Solens for the lows,and a clairity cap PX for the HF,and used a Mundorf resistor. Much better,and that brings up my question. I'd like to go the RDO 198 TL route,but clairity caps only offers a 5.6 in the px range,and I'd like to stay in that range.
Close enough,or use a .2 clairity SA cap with it? Also I didn't pull the 750 mica,when I do,do I use a jumper or just pull it?
Thanks for any info,and for all the info I've culled from this forum.
John
John
Post edited by cheezer on
Hi John,
Welcome to CP. I wonder if Clarity caps can be custom valued?
As you probably read, mAny of us buy Sonicaps from Sonic Craft and they custom value for about a buck fifty a cap. Clarity caps are sweet and it would be great if you could get one spot-on 5.8uf.
I think percentagewise 5.6uf is well within the parameters to replace a 5.8uf, but 5.8 is what Polk found to be ideal. I don't think it would be a good idea to bypass it with a .2uf. Even though capacitance is additive, the .2 becomes the path of least resistance and processes a disproportionate amount of the signal so my guess is the sound quality through a 5.6 + .2 would be different that from a proper 5.8 or a substituted 5.6 alone.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
and,, you can just remove the silver mica,, no need for it since you are using better capsJC approves....he told me so. (F-1 nut)
At 5% tolerance the 5.6 px will be fine, definitely don't add the .2. It will just act as a bypass cap and you don't want that. Enjoy, and welcome to CP!"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
The tl upgrade is really worth it! Go with the custom built Sonicap 5.8.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »The tl upgrade is really worth it! Go with the custom built Sonicap 5.8.
There is a lot of healthy interest in other brand caps.
I think the way to put it is that Sonicaps give you 95-97% of what is possible on a beer budget, but there are some champagne caps out there that approach 99.9%
Clarity Caps (MR MKP) are generally considered to be a step up from Sonicaps, albeit at a slightly higher cost.
Consider the Mundorf Supreme Silver Gold Oils if you really want to go there.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Thanks for the info guys. Guess it's time to start shopping. And I am on a beer budget here:biggrin:.Looks like I'll be into them for about $300 total-not bad. thanks again-John
