Midas Touch Phono cart isolator
doctorcilantro
The isolator (MIDAS TOUCH) has 3 spikes facing up and 3 spikes facing down, all adjustable and can be located to suite arm and cart. True isolation of the cartridge from the arm. You will hear better focus, better extensions and more solid sound. It is the same as having cones / spikes under the turntable and also speakers as well as equipment. The cartridge vibrates all the time while it is tracking.
there are some pics here.
The images are not mine. This is something I should probably keep but need to sell everything I'm not currently using.
$75 shipped CONUS.
$75 shipped CONUS.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
Will this work on any cartridge??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Good question. It won't work on Soundsmith carts, but Grados are fine obviously. Any cart with a large body (e.g. Zu) would fine. I can find the dimensions or check and post them here.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
I would only use it on arms with adjustable VTA (vertical tracking angle). By putting it between the mounting surface on the arm and the cartridge it will lower the cartridge in relation to the arm. To compensate you must raise the back of the arm to maintiain a similar VTA. I'm very curious as to how well it works but don't have enough spare coin right now. Good luck on the sale doc.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
still for saleFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
