Midas Touch Phono cart isolator
doctorcilantro
doctorcilantro Posts: 2,028
edited December 2010 in For Sale (FS) Classifieds
The isolator (MIDAS TOUCH) has 3 spikes facing up and 3 spikes facing down, all adjustable and can be located to suite arm and cart. True isolation of the cartridge from the arm. You will hear better focus, better extensions and more solid sound. It is the same as having cones / spikes under the turntable and also speakers as well as equipment. The cartridge vibrates all the time while it is tracking.
there are some pics here.
The images are not mine. This is something I should probably keep but need to sell everything I'm not currently using.
$75 shipped CONUS.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Post edited by doctorcilantro on
  • vmaxer
    vmaxer Posts: 5,121
    Will this work on any cartridge??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • doctorcilantro
    Good question. It won't work on Soundsmith carts, but Grados are fine obviously. Any cart with a large body (e.g. Zu) would fine. I can find the dimensions or check and post them here.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • Fongolio
    Fongolio Posts: 3,516
    I would only use it on arms with adjustable VTA (vertical tracking angle). By putting it between the mounting surface on the arm and the cartridge it will lower the cartridge in relation to the arm. To compensate you must raise the back of the arm to maintiain a similar VTA. I'm very curious as to how well it works but don't have enough spare coin right now. Good luck on the sale doc.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • doctorcilantro
    still for sale
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
