Polk rtia3
Ericw2431
Ericw2431 Posts: 228
edited December 2010 in Speakers
Ok so as i mentioned before i was going back to rtia for home theater!.....as i was settin up my rtia's 7 i looked at my A'3s hooked em up and gave em a shot as i was listening the left side bookshelf (a'3) woofer was rataling?! i thought i had it to high but the right side was perfect?! is the coil poped or what can i do?! sounds as if ur putting ur nail on the cone as it excursions...just to give a demonstration!....im really worryed because i was planning on selling the a'3s but didnt want to rip some one off! please help!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Post edited by Ericw2431 on
  • Ericw2431
    please some one help!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • RuSsMaN
    RuSsMaN Posts: 17,985
    What are your driving it with? If it is buzzing, you have probably come close to clipping your amp and heated (expanded) the voice coil slightly, and now you get a rubbing, scratching sound?
    Have you troubleshot at all? Swap left and right, listen and reasonable levels, with no loudness contouring, tone controls, or DSP's engaged and report back. What do you generally listen to, music or movies? If movies, how do you have your bass management setup, ie large / small and crossover point?
    Cheers,
    Russ
  • Ericw2431
    nope its just that speaker i swithed and it does it at reasonable listeing levels music its bearly noticable but on games such as battle field and movies like paranormal activaty 2 and kung fu panda it gets real chippy and starts to rattle as if the cone was loose?! aww and i have them set to small and crossover is set to 80hz
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
  • RuSsMaN
    Do us both a favor, and tomorrow morning call Polk Audio Customer Service at 1-800-377-7655 after 9am EST. If you have your original receipt, it would be helpful, but not necessary.
    I'll forward a note now via email, regardless, we'll get you up and running in short order.
    Cheers,
    Russ
  • Ericw2431
    thanks
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Amp:Emotiva xpa3
