best setup for rtia5,a1 and psw111?
After months of deciding I finally purchase a set of cherry rtia5s to go with my rta1 rears. They are beautiful speakers to say the least. Ordered thru polk so got the psw111 for free. Does what I need it to. The instructions on the psw111 say to set speakers at small and crossover at 80hz. It seems to sound a bit better than having the a5s set at large, which it seems logical to do so. Any suggestions on the setup of these speakers?
All set to small and sub crossover set to 80hz is a good starting point.
Let the sub handle the low freq, gives your fronts more headroom. My speakers are rated down to 25hz but I still run them small.2Ch Tube Audio Convert
Your sub should be better suited for the bass and can be placed in a better position to do so.2Ch Tube Audio Convert
