Is the Onkyo TX-SR707 good for my setup
Drake5
Drake5 Posts: 15
edited December 2010 in Electronics
I have the polk monitor 70 fronts and a cs 10 center and some old surround speakers ( to be replaced soon). Would the Onkyo TX-SR707 be a good receiver?
I especially like listening to 2.1 audio (m70 and sub) (via SACD player) and would like to know if the onkyo 707 will be good or will it still be under powered to bring out the best in the m70s?
Would bi-amping the two m70s using the surround outs of the 707 make my 2.1 listening more pleasurable?
Thanks.
Post edited by Drake5 on
  • nguyendot
    nguyendot Posts: 3,594
    Yes it will power your setup just fine. Biamping won't make any difference with that receiver unless you use preouts and 2 separate amps.
    Main Surround -
  • leroyjr1
    leroyjr1 Posts: 8,785
    Yes, it'll do just fine.
    EndersShadow Posts: 17,688
    nguyendot wrote: »
    leroyjr1 wrote: »
    What they said.
  • dorokusai
    dorokusai Posts: 25,576
    Yes.
  • aboroth00
    aboroth00 Posts: 1,106
    Yeap it's fine unless you're in a large room. If so just add a separate amp.
    2Ch Tube Audio Convert
  • dorokusai
    Even in a large room you'd be fine since it's 90+db efficient. If you live in a church, sure, that might be a valid comment.
  • dorourke07
    dorourke07 Posts: 298
    NIce choice.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • Gulfstrings
    Gulfstrings Posts: 313
    Drake5 wrote: »
    Thanks.
    The 707 was doing a nice job with my setup for nearly a year before I added the NAD amp. I believe you'll be very pleased with it's performance and features.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
