Thanks for advice...Now another issue
Hello All. Thanks for feedback on this newbies previous questions. After talking with you guys and Polk directly, I have decided not to use the LCI-C with my two TC265's. I hate to due this since i was able to get the center for $350 at an authorized retailer.
I am either going to use a third TC265 as a center or get the Csi A6. I would like it to be a total voice match by using the third TC, but need some suggestions on installing horizontal. I do not think it will install that way, but hopefully someone has a suggestion.
If not, how is the A6? Is their a huge differnce with the A4 instead? Will I have any voice matching issues?
Thanks for all forum members help!!!!
According to Polk the Csi A6 is a timbre match to your in-walls. I don't think you could mount the Tc265's horizontal.
Don't scrimp on the Center channel. For movies it is the most important. I would go A6 all the way. It is a very nice Center.
