About to create custom home theater...Need Advice!!
Hello. I am about to begin working on my home theater room. I already have a7.1 channel system pre-wired into the room from pre-construction, but no enclosures. I recently purchased two TC265i's, LCi-C and a PSW 125 sub ($50 with promotion). I plan on getting for RC80i's for the rear surrounds.
I was hoping to gain some insight on the speaker connectivity and harmony. Would there be a signigfcant problem for having the above set up? I know the timbre's are not matched.
In regards to installation, do you guys recommend placing insulation around the speakers and fill wall cavities with some as well? I read that since the TC265's use the wall enclosure for bass, I did not want to impede the speakers design purpose. If so, will R-11 rolled insualtion work well??
Any feedback will greatly be appreciated. Thank you all.
Post edited by Gomez81 on
Insulation would provide some dampening. The speaker would trade off some boominess for a little tighter operation. While not needed here is what you could really consider: LCi Performance Enclosures or some other back box. -
Any walls that I have done in-walls for I have added insulation or a back box. You don't want the speaker in an empty wall cavity.
Will the insulation take away from the "Infinite Baffle Tuning " design Polk engineered? OR would stuffing wall cavity and just leaving space behind speaker with out insulation, improve the sound and bass? I want the bass output, but do not want to sacrifice audio quality for it.
I would have loved to have enclosures built in. I have looked at duramat and other enclosures, but pricing is too much. Wife already can not get her head around me spending $1000 on just L/R/C channels (plus free sub). I have to do this econmically. What type of insulation do you guys suggest? R-11?
If I have to build a box behind, any recommendations??
Thank you for your help!!! -
Infinite baffle refers to the fact that the speaker is flush mounted to the wall.
Any surface that a speaker radiates from is a baffle. Some are infinite (like a wall) and some are not (like a 9 inch wide speaker cabinet).
When a speaker is mounted in a traditional speaker cabinet baffle step compensation is built into the crossover.
Here is a good lay persons read on BSC. -
You wouldn't build anything. Just purchase some back boxes that will work with your inwalls. Try Partsexpress.com. Give them a call and they should be able to help.
R 11 would be fine. Just normally line the wall cavity as you normally would.
