McIntosh 2105 vs Bryston 4b opinions
erniejade
erniejade Posts: 6,321
edited December 2010 in 2 Channel Audio
I currently have a McIntosh 2105 but have a chance to trade for a Bryston 4b. http://pic5.audiogon.com/i/c/f/1291420228.jpg
I have never heard a Bryston but I have heard they are a great amp and the 4b was a fantastic amp.
Has anyone heard them side by side? Any opinions either way?
Post edited by erniejade on
  • erniejade
    I am not sure but is this the 1st series 4B? it looks like it went through some changes over the years from 200 WPC to 250 and now 300.
  • FTGV
    FTGV Posts: 3,650
    erniejade wrote: »
    It looks to be of mid -late 80's vintage(pre NRB series) so just outside of the 20 yr warranty.
  • erniejade
  • FTGV
    FTGV Posts: 3,650
    erniejade wrote: »
    Yes that chassis style was used in the time frame I mentioned.Some of the later ones will have toroidal transformers instead of EI core types as this is when they began the transition to them.
    tonyb Posts: 33,069
    I've had an ear on both of those amps. Now,just my opinion, but the later 4b had alot of grunt on the low end,very powerfull but a tad harsh up top. The Mac wasn't as tight down low but had a silky smooth top to it.
  • FTGV
    FTGV Posts: 3,650
    tonyb wrote: »
    Bass control and slam are definately a Bryston hallmark.
    ... but a tad harsh up top.
    Thats the general consensus on the older units so they might not be the best match for speakers with a rising top end.The newer generations are more refined in the upper mids and treble whilst retaining the potent bass performance.
  • erniejade
    Tonyb thank you that is what I was looking for. I know not everyone has heard the 2105 let alone know the Bryston line up. It seems the 4b has a lot of different changes over the last 20 years. I have always heard great things about bryston and can trade even up.
    The other small thing I have to consider is re-sale, the McIntosh will hold its value and 10 years down i can still get 7-900$ for it. Where as the bryston that might not be the case. I have a habbit, like many of us on here, to buy and sell. Whatever I do I usually break even on the gear. I am not sure if i would break even if i sell it in a year or so if I trade for the McIntosh.
    I might save up and look for ST version.
  • leftwinger57
    leftwinger57 Posts: 2,917
    I never had either of these amps, w/ saying that if I had a choice I would go w/ the Mac 2105. Just the glow of those famous meters and at 105wpc not bad. The Bryston looks like my Adcom gfa555 200wpc just a little smaller. If I had cash o plenty it would be a 2105 / c-28 pre and some ESS HEIL AMT-1S.
    living in the past if you can afford it is fun I hear. I can not and don't so it's
    Adcom>Onkyopre>Infinity sm112s>Denon1940ci cdp.....LW
  • erniejade
    Your right. On looks alone the mcintosh has it hands down. Something about the glowing meeters that is always pleasing.
