mono or 2-channel amp?
spartankicker43spartankicker43 Posts: 3
edited December 2010 in Car Subwoofer Talk
I have 2 subs, max handling 300 watts a piece at 4 ohm.
do i need a mono or 2 channel amplifier?
Post edited by spartankicker43 on
  • KennethSwaugerKennethSwauger Moderator Posts: 6,846
    Hello,
    If it were me I would look at a good quality monobloc power amp that can work into a 2 Ohm impedance. Then connect the two subs in parallel and you should be fine. Most amps will have adjustable low pass filters to allow you to get your subs tuned in with the rest of your system.
    Cheers, Ken
    "They thought we were too loud, but shoot, I had four army blankets folded over my amp, and the volume level was on 2. I'm used to playin' on 10!" S.R.V.
  • PerfectCreaturePerfectCreature Posts: 1,457
    Generally for a 2 ohm load a monoblock is desired. For a single 4 ohm load, 2 channel is the cheapest and most effective means.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • TopperTopper Posts: 403
    the new polk pa880 mono amps should be something to look into:
    http://www.polkaudio.com/caraudio/pa/index.php#pa880_1
Howdy, Stranger!
