mono or 2-channel amp?
spartankicker43
I have 2 subs, max handling 300 watts a piece at 4 ohm.
do i need a mono or 2 channel amplifier?
Post edited by spartankicker43 on
Hello,
If it were me I would look at a good quality monobloc power amp that can work into a 2 Ohm impedance. Then connect the two subs in parallel and you should be fine. Most amps will have adjustable low pass filters to allow you to get your subs tuned in with the rest of your system.
Cheers, Ken -
Generally for a 2 ohm load a monoblock is desired. For a single 4 ohm load, 2 channel is the cheapest and most effective means.Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
the new polk pa880 mono amps should be something to look into:
http://www.polkaudio.com/caraudio/pa/index.php#pa880_1
