RT1000p Amp Fuse
gfudala
gfudala Posts: 3
edited January 2004 in Troubleshooting
It may be wishful thinking at this point, but my dead RT1000p amp blew a fuse and I'd like to try replacing said fuse first.
What is the amperage on this fuse? It's not clearly marked on the fuse itself. I see "T1L250V", so I feel pretty good about it being 250 volts. :)
Post edited by gfudala on
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2004
    Welcome to the forum - Nice speakers. They were my very first Polks and very few people own the old reference 1000 models.
    I have never blown a fuse on mine in the last 7 years. Do you have the manual it may be in thier. Or talk to Polk Cust. service and they will be glad to help. ;)
  • gfudala
    gfudala Posts: 3
    edited January 2004
    Hey Scott,
    Glad to be here! They have really served me well for... 5½ years now. Until this one croaked, of course. :)
    I did check out the manual, but there are no such technical details there. If I don't see a response here, I'll give Polk support a call & then post my findings.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2004
    Hello Scott,
    The AC fuse for the RT1000p speaker is 1 Ampere, 250 Volt, time delay type that is 5mm x 20mm in size. However, unless you have experienced a power surge, where you live, a blown fuse is indicating a problem with the amplifier. In other words, replacing the fuse might not solve the problem.
    Regards, Ken
  • gfudala
    gfudala Posts: 3
    edited January 2004
    Thanks for the details, Ken. I'm suspicious that it might have been a power surge, as the voltage at my place fluctuates a fair amount based on what I see on my line conditioner... 2 of my RT1000p's are my rear channels, and thus were plugged directly into the outlets with no filtration or protection.
    I swapped the fuse out... so far, so good.
    Gene
  • [Deleted User]
    edited January 2004
    Hello Gene,
    I hope the fuse is the answer.
    Regards, Ken
