Polk LS90 front panel question
nclh7
nclh7 Posts: 38
edited December 2010 in Vintage Speakers
I have been noticing two different looks to the front of the LS90. One is totally flat, the other has what appears to be a bit of a recessed panel with a Polk Audio label just below the bottom driver(both with the covers off).
Am I not seeing things correctly?
file.php?id=6915
Post edited by nclh7 on
    F1nut Posts: 51,763
    It's a trick of the light.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    The first has had what the 2nd has removed. That flange is notorious for coming loose over time.
    Cheers,
    Russ
