Bi amping RTi a5s
recover
recover Posts: 14
I"ve got an Onkyo TX NR -708 That I'm going to be running my 5.1 setup. Are the A5s set up for bi amping and is it the way to go?
Post edited by recover on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited December 2010
    Yes, they can be bi amped but will not made a difference, they're very efficient speakers.
    I'd say atleast give it a try so you'll know for yourself.
    EndersShadow Posts: 17,715
    recover wrote: »
    They are not setup for bi-amping sorry :frown:
  • leroyjr1
    Yes they are.
  • nguyendot
    nguyendot Posts: 3,594
    leroyjr1 wrote: »
    Yes they are.
    Passive bi-amping unless you remove the crossover.
    Main Surround -
    leroyjr1 wrote: »
    Yes they are.
    My apologies, Polks spec's list them as only having 5 way binding posts v. the dual 5 way binding posts listed for the A7's
  • recover
    recover Posts: 14
    That's what made me wonder myself
  • recover
    recover Posts: 14
    leroyjr1 wrote: »
    I'll try it and let you know
    F1nut Posts: 51,925
    Bi-amping with an AVR is not bi-amping as all the channels share the same power supply, so don't bother as it is a complete waste of time and energy.
    Glad I'm not the only one preaching this wisdom. Sick 'em Jess.
  • recover
    recover Posts: 14
    Please don't beat me down to hard but I figured 110w of power would be a plenty for these towers. Does it allow you to crossover each comp. for more controll?
    F1nut Posts: 51,925
    I'm unsure what it is that you are asking.
  • WilliamM2
    WilliamM2 Posts: 4,808
    recover wrote: »
    No, you are stuck with the crossovers in the speaker, they can't be bypassed. No matter, I'm sure Polk picked the best crossover frequency for the drivers used.
  • recover
    recover Posts: 14
    Thanks guys!! Now if I can just figure out how to run this reciever I'll be alright. I have more experience with car audio and that helps by having a general understanding but this AVR does everything!
    Read the manual,even the parts you may think don't apply to you. Car audio is a little different but some principles are the same. Good luck and let us know how it turns out.
