brand new to home theater.
partyboy53551
partyboy53551 Posts: 2
So i went out on black friday and found some great deals. I ended up with a pair of rti8's, a h/k 1600, and a psw 505 to boot. Im almost all home theater, but have to stay with the 2.1, maybe talk the wife into a center for 3.1. Im wondering if the cs20 would be a match or not? Also if anyone is familiar with the reciever do i set up the sub for present, or 12? I have the fronts set to small with 80 crossover. Anything else I should really be looking into in your opionion?? The ezet on th h/k wont work without a min. of 5.1 setup. Can i fool it with a bunch of my old speakers and then remove them?
Post edited by partyboy53551 on
  • ohskigod
    ohskigod Posts: 6,505
    edited December 2010
    the RTi center is actually called the CSi
    CSi A6 bigger
    CSi A4 smaller
    this will timbre match. very important to have your center timbre match, that cs20 will not be. Take your time and save up. with a center not having one can be better than having the wrong one.
    with those RTi8's, I would get the bigger center, thats my .02, but the smaller one will tibre match and be much better than none.
    welcome to the club, home theater can be addicting.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Zeros
    Zeros Posts: 940
    Lasareath wrote: »
    You would want to get an Rti center as well.
    As per the rest of your questions I'm sure some peeps will chime in.
    And by Rti center, Las means a CSi5 preferably. If not , go with a CSi3.
    Edit: or what Ohski said above.
  • Ricardo
    Ricardo Posts: 10,634
    Actually the right match for the RTi8's would be the CSi5. You should be able to find one for cheap and it's one of the best centers Polk has ever made.
    Welcome!!
    SOPA
  • Knucklehead
    Knucklehead Posts: 3,602
    I have that set-up as well, the CSi5 is a fantastic center., Its a monster, make sure you have room for it. :)
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • partyboy53551
    Thanks for the input, ill be keeping an eye out for the csi5!!!!
  • Sherardp
    Sherardp Posts: 8,038
    CSiA6 if you can't find the CSi5. Same speaker slightly different design in the cabinets.
