Thanks club polk and question
doc5150
doc5150 Posts: 8
edited December 2010 in Speakers
Hello! I just replaced all my HT system, I came here looking/researching for nice speakers and everyone pretty much made up my mind by just reading your comments :) And you all were correct, I got the m70's, cs20 and lsi 100's along with a new/slightly used floor model Denon avr 4310ci for a great price. It sounds amazing and I thank you!
Now my question, in my old system I used a Definitive prosub 1000, but it has issues, it works but has a annoying radio interference type noise like bad am signal. It still does it on the new reciever so it must be trashed. What would you all suggest for a new sub? Would a psw505 be better than what i had or should i go for something nicer that wont break the bank?
Thanks,
Doc
Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
Def Tech Prosub 1000
PS3 60GB
Denon ipod dock
Post edited by doc5150 on
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited November 2010
    doc5150 wrote: »
    Thanks,
    Doc
    Welcome to Club Polk doc5150 :smile:
    Interference in your sub does not mean it is gone. A little troubleshooting can lead you a long way.
    Have you tried switching your sub cable (maybe defective and acting as an antenna)?
    Is you sub cable crossing any other cables (picking up the interference from other cable)?
    Isolate your sub from anything else and see if the interference is still there. If not (more likely) start reconnecting each pieces until noize reappear. Others will chime in with pointers.
    As far as the 505, yes a good combo with your M70s.
    Congrats on your new speakers :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • doc5150
    doc5150 Posts: 8
    Its not the cable, all you have to do is plug in the power, in any room with nothing connected to it, turning either volume or crossover knobs make no difference.
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • thsmith
    thsmith Posts: 6,082
    does your sub have a ground pin on the AC cable ? If so try lifting the ground by using a cheater plug.
  • doc5150
    doc5150 Posts: 8
    @thsmith: yes it does....I will try that when i get home. Thanks for the suggestion
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • TECHNOKID
    thsmith wrote: »
    That would more likely apply for a ground loop I am not convince that it would help in this situation however, the OP has nothing to loose and potentially everything to gain.
    DARE TO SOAR:
  • doc5150
    doc5150 Posts: 8
    I was wrong,it doesnt have a ground pin. Im guessing it has a problem with the electronics inside :(
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • TECHNOKID
    doc5150 wrote: »
    I really have a hard time to conceive that. Take your time, don't give in so quickly (unless you are druling about a new sub and this is the perfect excuse :wink:)?
    Are you confident opening the sub and taking a look inside? The only problem I could see inside the box is a potential wire or some of the sort that is un-hooked and act as an antenna :confused: You mention the radio signal issue but also mentions it still works, has to be some simple....
    Doesn't have a ground pin as never did or was removed?
    DARE TO SOAR:
    tonyb Posts: 33,068
    He could also try grounding it himself with a small wire from the plate to the wall socket screw. Otherwise,pop the top and look under the hood.
  • doc5150
    doc5150 Posts: 8
    Ok, added a ground and no change, even hooked it up to a different speaker. I disconnected the wired inputs, see no soldered areas on pcb that were loose. When I unplug the speaker its silent, wondering if the amp itself is doing it, doesnt change pitch or anything with volume or crossover knobs. Just realized it not shutting down with no signal after sittng there plugged in for awhile. I will keep looking :)
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • doc5150
    doc5150 Posts: 8
    I called Definitive tech support, this thing is atleast a year or 2 out of warranty, The tech guy was so nice he said " I'll tell ya what, gimme ur name and address and i will send you a whole new amp assembly free of charge" I about shoit myself....He said the output stage of the amp failed..Thanks for saying don't give in so early Technokid :) I still may add a 505 since my HT area is good size (open basement) Thanks everyone for the help, i will update when the part gets here!
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • nguyendot
    nguyendot Posts: 3,594
    New LSI model?
    Main Surround -
  • doc5150
    doc5150 Posts: 8
    naa, the psw505, you can get one for about 200 or less if you catch it at the right time for a sale price on Newegg. The sub im trying to fix is a definitive prosub 1000.
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
  • doc5150
    doc5150 Posts: 8
    Received the new amp free of charge, installed and back in buisness , still may add a second sw because of room size. Thanks again for the help :)
    Denon AVR 4310ci
    Polk M70 series II
    Polk CS20
    Polk Lsi 100
    PS3 60GB
    Denon ipod dock
