Thanks club polk and question
Hello! I just replaced all my HT system, I came here looking/researching for nice speakers and everyone pretty much made up my mind by just reading your comments
And you all were correct, I got the m70's, cs20 and lsi 100's along with a new/slightly used floor model Denon avr 4310ci for a great price. It sounds amazing and I thank you!
Now my question, in my old system I used a Definitive prosub 1000, but it has issues, it works but has a annoying radio interference type noise like bad am signal. It still does it on the new reciever so it must be trashed. What would you all suggest for a new sub? Would a psw505 be better than what i had or should i go for something nicer that wont break the bank?
Thanks,
Doc
Thanks,
Doc
Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
Def Tech Prosub 1000
PS3 60GB
Denon ipod dock
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock
Welcome to Club Polk doc5150Hello! I just replaced all my HT system, I came here looking/researching for nice speakers and everyone pretty much made up my mind by just reading your comments
Thanks,
Doc
Interference in your sub does not mean it is gone. A little troubleshooting can lead you a long way.
Have you tried switching your sub cable (maybe defective and acting as an antenna)?
Is you sub cable crossing any other cables (picking up the interference from other cable)?
Isolate your sub from anything else and see if the interference is still there. If not (more likely) start reconnecting each pieces until noize reappear. Others will chime in with pointers.
As far as the 505, yes a good combo with your M70s.
Congrats on your new speakers :cool:DARE TO SOAR:
Its not the cable, all you have to do is plug in the power, in any room with nothing connected to it, turning either volume or crossover knobs make no difference.Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
does your sub have a ground pin on the AC cable ? If so try lifting the ground by using a cheater plug.Speakers: SDA-1C (most all the goodies)
@thsmith: yes it does....I will try that when i get home. Thanks for the suggestionDenon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
That would more likely apply for a ground loop I am not convince that it would help in this situation however, the OP has nothing to loose and potentially everything to gain.does your sub have a ground pin on the AC cable ? If so try lifting the ground by using a cheater plug.DARE TO SOAR:
I was wrong,it doesnt have a ground pin. Im guessing it has a problem with the electronics inside
Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
I really have a hard time to conceive that. Take your time, don't give in so quickly (unless you are druling about a new sub and this is the perfect excuseI was wrong,it doesnt have a ground pin. Im guessing it has a problem with the electronics inside
Are you confident opening the sub and taking a look inside? The only problem I could see inside the box is a potential wire or some of the sort that is un-hooked and act as an antenna
You mention the radio signal issue but also mentions it still works, has to be some simple....
Doesn't have a ground pin as never did or was removed?DARE TO SOAR:
He could also try grounding it himself with a small wire from the plate to the wall socket screw. Otherwise,pop the top and look under the hood.HT SYSTEM-
lsi 9's -
Ok, added a ground and no change, even hooked it up to a different speaker. I disconnected the wired inputs, see no soldered areas on pcb that were loose. When I unplug the speaker its silent, wondering if the amp itself is doing it, doesnt change pitch or anything with volume or crossover knobs. Just realized it not shutting down with no signal after sittng there plugged in for awhile. I will keep looking
Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
I called Definitive tech support, this thing is atleast a year or 2 out of warranty, The tech guy was so nice he said " I'll tell ya what, gimme ur name and address and i will send you a whole new amp assembly free of charge" I about shoit myself....He said the output stage of the amp failed..Thanks for saying don't give in so early Technokid
I still may add a 505 since my HT area is good size (open basement) Thanks everyone for the help, i will update when the part gets here! Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
New LSI model?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
naa, the psw505, you can get one for about 200 or less if you catch it at the right time for a sale price on Newegg. The sub im trying to fix is a definitive prosub 1000.Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock -
Received the new amp free of charge, installed and back in buisness , still may add a second sw because of room size. Thanks again for the help
Denon AVR 4310ci
Polk M70 series II
Polk CS20
Polk Lsi 100
PS3 60GB
Denon ipod dock
