Speaker setup help
acs_rpeters@msn
I just got new monitor 70's and CS2 Center. I have ran the Audyssey setup and just not sure its setting it where it should be. Any feedback would be greatly appreciated.
AVR-Onkyo TX-SR606
Front-Polk Monitor 70's
Center-Polk CS2
Surround- Polk RM85
Sub- Sony POS
Results:
Polk Monitor 70's = Full Band
Center-Polk CS2 = Full Band
Surround- Polk RM85 = 120hz
LPF of LPE = 100hz
AVR-Onkyo TX-SR606
Center-Polk CS2
Surround- Polk RM85
Sub- Sony POS
Results:
LPF of LPE = 100hz
Post edited by acs_rpeters@msn on
Trysetting your crossover on the avr to 80 for the fronts and center.Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
acs_rpeters@msn wrote: »I just got new monitor 70's and CS2 Center. I have ran the Audyssey setup and just not sure its setting it where it should be. Any feedback would be greatly appreciated.
Audyssey is notorious for listing most floorstanding speakers as full band. It did the same to my Monitor 60's. I set the crossover to 70 and called it a day."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I don't see a sub mentioned in your sig. You do have one correct? What is it?
A Sony POS sub might not even be capable of playing as low as your 70s. If that's the case, you may want to just try setting the speakers to full range and eliminate the sub for now. Look up the sub model number and see what the specs are.
Found my manual. Its a Sony SA-WMSP85 and range is listed from 28hz-200hz.
I'm looking to replace in a month a 2 and was looking at the Polk DWS MicroPro 2000 but not sure if thats over kill -
Turn the crossover on the sub all the way up and adjust the crossover in the receivers menu at around 70. That Sony sub is not the best my friend. Do your speakers sound like they are overpowering the sub ? If so, just take the sub out of the mix, in the menu set the sub to "no", the receiver will route the sub signal to all other full range speakers.HT SYSTEM-
