Speaker setup help
acs_rpeters@msn
acs_rpeters@msn Posts: 32
edited December 2010 in Speakers
I just got new monitor 70's and CS2 Center. I have ran the Audyssey setup and just not sure its setting it where it should be. Any feedback would be greatly appreciated.
AVR-Onkyo TX-SR606
Front-Polk Monitor 70's
Center-Polk CS2
Surround- Polk RM85
Sub- Sony POS
Results:
Polk Monitor 70's = Full Band
Center-Polk CS2 = Full Band
Surround- Polk RM85 = 120hz
LPF of LPE = 100hz
Post edited by acs_rpeters@msn on
  • cnoat
    cnoat Posts: 315
    Trysetting your crossover on the avr to 80 for the fronts and center.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
    EndersShadow Posts: 17,715
    Audyssey is notorious for listing most floorstanding speakers as full band. It did the same to my Monitor 60's. I set the crossover to 70 and called it a day.
  • McLoki
    McLoki Posts: 5,231
    I don't see a sub mentioned in your sig. You do have one correct? What is it?
    Michael
  • mdaudioguy
    mdaudioguy Posts: 5,164
    A Sony POS sub might not even be capable of playing as low as your 70s. If that's the case, you may want to just try setting the speakers to full range and eliminate the sub for now. Look up the sub model number and see what the specs are.
  • acs_rpeters@msn
    Found my manual. Its a Sony SA-WMSP85 and range is listed from 28hz-200hz.
    I'm looking to replace in a month a 2 and was looking at the Polk DWS MicroPro 2000 but not sure if thats over kill
    Turn the crossover on the sub all the way up and adjust the crossover in the receivers menu at around 70. That Sony sub is not the best my friend. Do your speakers sound like they are overpowering the sub ? If so, just take the sub out of the mix, in the menu set the sub to "no", the receiver will route the sub signal to all other full range speakers.
