Bass management settings for HT
larryh
I have a Yamaha HTR-5250 A/V and the following Polk speakers: main - RT600i; center - CS400i; surround -f/x300i and subwoofer -PSW250. I am not certain whether I should select large or small for the center and main speakers, and either the subwoofer or both position for bass out on the receiver set up. I currently have speakers set to large anbd subwoofer to both, but sometimes the dialogue tracks sound a little muddy on DVD and TV. I'm a little hard of hearing and am trying to get the clearest reproduction I can on the dialogue tracks. The RT600i instruction manual doesn't indicate whether the setting should be large or small and the CS400i is a little ambivalent on the issue. I know that no one can hear through my ears but me, but I would appreciate any advice you might give. Thanks, Larry
Post edited by larryh on
I would set all of your speakers to small. I don't know what subwoofer to 'both' means, but hopefully someone with a Yamaha can better help you there. But I would definitely set your speakers to small.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Larry, Set all speakers to SMALL and buy a buffer subwoofer. Run the center a couple clicks hot. Mud will go - amp work cooler.
Thanks for your help. The subwoofer setting has three choices: subwoofer only; both, which channels low frequencies to both the mains and the subwoofer, and none. If I set the mains to large, I use both; if I set them to small, I should probably use subwoofer only. Would you agree with that? Thanks, Larry
Ya, most recievers automaticly send the bass to the sub when set to small. Both would be a LARGE setting on the mains anyway.Originally posted by larryh
Strange option........ -
edit - been twicking computer lately and my browser is not updating post correctly.
Yes, set all speakers to small and select sub only.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
Larry, to confirm what L&C said, set all speakers small and set subwoofer only, not both. That'll then roll off the speakers below 90Hz and send that bass to the sub alone. Be sure to adjust the sub output so that it isn't so loud that it draws attention to itself as a separate source; the impression should be that the sub isn't working but that the other speakers are putting out more bass.
If set main SMALL, shall you also remove the gold plate on speaker post and connect only top post?
Thanks,
CT2Mains: RTi70
Center: CSi40
Surrounds: FXi50
Rear Center: Not yet
Sub: STF-2
Receiver: HK AVR120/ Yamaha RX-V1400 -
Experiment with both settings and see what sounds best for you.
Dan -
No, then only the tweeter will work. The seperate post are for Bi-Amping. Nothing to do with large or small.Originally posted by CT2
Thanks,
CT2 -
Actually, what I learnt fron this forum is that bottom post are for
bass and top post are for high and mid range. If bass signal will
be handled by seperate sub, I would think it's better not send signal to main's woofer, this will also make mid and high more clean. Am I totally wrong here?
Thanks for any input,
CT2Mains: RTi70
Center: CSi40
Surrounds: FXi50
Sub: STF-2
CT2,
Thier are several different speakers Polk makes. If you are talking about a powered sub tower, then ya you are right but still wrong. They can not be bi-amped. The bottom post are for the input signal to the sub amp and even then you can use the rca analog inputs. On most if not all other models - top tweeter and bottom drivers.
Even set to small on my RT1000p's the internal sub puts out tons of bass, it is just not as deep (thus also they were not designed for really low bass anyway) and therefore can be cranked up a bit more.
Did I confuse ya!!!!!!
Yes, CT, you've misunderstood. The crossover done by the filter in the receiver, generally around 80Hz, sends the bass below that frequency to the sub, but frequencies above 80Hz are still handled by the lower driver in the main speakers; in some cases this is up to 3,000Hz or higher. If you disconnected the strap you'd have only the upper section of the speaker operating and the frequencies from around 80Hz up to 3,000Hz, or as high as the lower speaker goes, would be mostly lost.
