head unit questions from a born-again n00b
concealer404
Alright, so i'm wanting to run front, rear, and sub.
I would like all channels to be externally amplified, since i hate headunit amps for various reasons.
Now. (prepares for gnashing of teeth.) I'm not hacking up my doors, i'm not going to mess with custom enclosures/kickpanels/whatever.
So. Here's what i've got.
CDT 4"/1" components for front. CDT 6.5" midrange ONLY in rear, and two 8" CDT subs.
I got it all on the cheap, and i'm a cheapass. Looking for a big fat double din headunit. Most of them that i like and am willing to pay for, have only two sets of preouts. Front, and rear/sub.
Proposed solutions that i've thought of:
1) Split the preouts for Front into front and rear, and then filter using the amp. Block high range to rear speakers, and roll off the lows from the front 4s.
2) Split the preouts from Rear/sub, and do the same there. Set HPF/LPF for sub, and same for rears on amp.
3) Sack up and get something with 3 sets of dedicated preouts.
Are they all viable? Or just option 3?
Next question:
I found a Pioneer DEQ-99 for a decent price. Are EQs like this worth bothering with? IF so, being that the DEQ-99 has 3 sets of preouts, how would one make this work with another pioneer headunit that might only have 2 sets of preouts. Again, the goal here is to end up with all channels amped externally.
Unless i'm missing my guess here, i could use ONE set of preouts from the head unit to feed into the DEQ-99, and then the DEQ-99 will feed that through three ouputs, and i can use it to filter as i see fit. Am i on the right track? (Bonus points is that i get more dancing lights, and my inner "ricer" likes this.)
http://cgi.ebay.com/Japan-Pioneer-DEQ-99-DSP-Equalizer-Graphic-EQ-/360322009241?pt=LH_DefaultDomain_0&hash=item53e4dd8899
Thanks in advance for any help/input.
Next question:
Post edited by concealer404 on
I wouldn't run rears, but its your ride, ears and dosh
I'd run the 6.5" upfront and the 4" in the rear. Of your proposed solutions I would go with 3.
Cody would know if the dancing lights can interface with another hu. If they can, then jump on them. -
Can't fit 6.5s up front without doing kick panels or hacking my door panels. :frown:
The EQ will accept a set of RCA inputs, so i think that'll work, and give me the bonus of being able to adjust everything on the fly rather than going to my trunk to mess with the amp.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
If you can afford the Pioneer, its worth it. Its always worth it to have as many EQ bands as possible. Ideally you want 31 bands PER SPEAKER. Of course youre not gonna get that in a head unit but the more you can get the better.
So yes, if you can fit it in your budget, get the head unit with the best tuning features cause theyll come in handy.
You also want 3 preouts. Yes you can split the RCA's but being able to actually control the level of front and rear speakers independently of each other is pretty important and definitely worth spending a few bucks for.polkaudio sound quality competitor since 2005
Now, that pioneer EQ seems to only have one pair of RCA inputs. Would it not just take a full range signal from the front RCA preouts from the headunit, and then i can manipulate the signals as i see fit through the front, rear, and sub outputs from the EQ?
I guess i'm asking if i'm right in thinking that because the EQ has one set of inputs, and three sets of outputs, if it negates the "need" for 3 sets of outputs from the headunit?
Thanks for the help so far guys.
concealer404 wrote: »I guess i'm asking if i'm right in thinking that because the EQ has one set of inputs, and three sets of outputs, if it negates the "need" for 3 sets of outputs from the headunit?
Yea thats correct. Congrats on snagging it
Unfortunately, despite the fact that it'll be available for the last 2 months or more, someone else got it literally minutes before i logged on to pull the trigger.
No big deal, although it was way cheaper than the US equivalent (DEQ-9200) usually goes for.
Oh well. C'est la vie. I'll just pay another $100 for one here.
But thank you affirming my thoughts.
If you're buying used you should be able to get a p-800/880 for about $270. That would be much better than the DEQ-99. The 99 gives you TA, the ability to go active but it only gives you a 3 band eq. The prs gives you the same TA, slkightly better xover network and a true 16 band independent l/r eq. Hook this up, run active and you would have great tuning flexibility.
Just a thought. -
Hrmm... that looks like a pretty decent headunit. My only complaint is that it isn't a double din.
Will do more research, thanks for the tip.
Just a thought.
Where did you find it. I have looked, and seem to find it anywhere. I was wanting to get one of these as well, but just can not find it. Link please????2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org -
If you can't find it, I might be willing to part with my other P860.
Hmmmmm....... Might be worth it. Have questions though. Sent you a PM on this.
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
I'm talking about the units that pop up from time to time. Thats about what they go for. Have some patience my son. Rome wasn't built in a day
Yes caesar
. It just really sucks, because I had found the DEH-P800PRS at one point, but did not get it cause I did not have the money. I now have the money, and what do you know it is no longer available. I should have bought then...... Oh well. I know that woofersetc has the DEH-P800PRS, and the DEH-P880PRS on their site, but the availability shows as discontinued, but they have a price next to it. So, Im not sure if that means that have it or not. Im guessing they dont. Oh well....... Such is life.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
How will you ever live without your trustworthy friend, bluetooth?
LOL. I now have a ear piece, and have come to terms with not having it the car. I figure if Im trying to get good sound then I have to sacrifice some things I.E. Bluetooth, and USB connect cord. However as for USB connection, I can always get an adaptor to integrate into the HU. So, yeah you got me.. Cant have your cake and eat it to..........:rolleyes:
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
