First complete setup
jimjangle
jimjangle Posts: 2
Hey polk guys n gals just got on the site and would like some opinions on my setup.
I'm running Tsi 400's for the fronts, a CS10 for the center, 4 OWM3's for the surrounds and a PSW110 for a sub. I like the way it sounds, but I'm really thinking about getting a CS20 to replace the center. The 400's are a little big. for the future i'd like to get some new surrounds but I don't really see any problem with what I have running for those right now.
All this is run off a SONY STR DG-820
I just moved so my setup is a little different but you can check some pics out
here http://www.blu-ray.com/community/gallery.php?member=JimJangle
Post edited by jimjangle on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited December 2010
    I dig the setup, the CS10 is way too low, especially with the furniture right in front of it. I don't see much way around it, unless you hang the tv on a mount and use the top shelf.
    Cheers,
    Russ
  • nguyendot
    nguyendot Posts: 3,594
    Your setup is actually very clean and put together well.
    I agree with RuSs.... The center channel is too low. Even with it angled up I can see the sound is firing directly into that table. I would move it up further, or move the table for better sound.
    I like clean setups like this, it makes me want to rewire everything in my setup....
    Main Surround -
