Hsu!
As many of you know i was confused on buying a sub! i finally saved up and got the hsu vtf3 mk3 That i bearly purchased today!...i caint wait till it gets here! as i previously stated i bought the micropro2000 but bearly impressed me!
....so i sold it to my brother and bought this beast! :biggrin: anybody think i made a mistake and should have saved up more to get a better sub i want this thing to pound my chest on movies! if you know what i mean!?
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
Post edited by Ericw2431 on
ha yes i dont want to tear down my house now maybe in the future! when i get a better job and a dedicated home theater! =]Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
i was just talking about this sub earlier today. i really dug it in my HT. Its a hard hitter and its extension is into the teens maybe 16 or 18Hz (?)
Anyways, it was my friends and he kept it, but i found it super detailed as well as very hard hitting for a moderate sized room (20' x 24')
hope you love itdesign is where science and art break even. -
20 x 24!? =O must be louder in my room as its fairly small!...but will do a review when i get i! =]Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
Eric, the 3 3 is a great sub depending on room size. WHat is your cubic feet and are there opening to other rooms, what are those measurements?
My room is 15x25x10 with opening to room 10x14x10.
I could bottom out the HSU on some movies. Not the subs fault just too much room.Speakers: SDA-1C (most all the goodies)
Eric,
Give us your impression, once you set it up. -
Sorry guys!!! that was supposed to say 20x14 not 20x24! OOPS
and btw 8' ceilingsdesign is where science and art break even. -
Should have saved for a little longer and got the new VTF-15H
I've got the 3.3 and its a very detailed sub, with a good amount of output. I too have managed to bottom it out, but I'm in a huge room (24x14x20). Even given the size of my room though, I'm only able to bottom it out at levels that are much too loud and drown out the rest of my system.
I'm running mine in 'overdamped mode' (one port open, max output mode). Extremely nuanced and detailed across the whole frequency spectrum. I bought a HSU MBM to reinforce the mid-range and it sits in a closet as I've found I don't need it!My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
With a room that large, Dual ULS-15s would be nice
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
and btw 8' ceilings
if your room has no opening you are set. at 2200cf the 3 3 will blow you away.
To get the best from any sub you need to find best location to raise any dips and if needed something to clip the peaks.
A lot of people throw down on their sub thinking just set it in the corner and run audessy on their AVR.
In most cases they are not even close.Speakers: SDA-1C (most all the goodies)
Hey guys. I've lurked a lot and posted once. My room is 15x22 9ft ceilings and opens to a room 12x9. Any suggestions on what to do with for a sub woofer?
to the OP:
take your time setting up the sub, try as many different locations/angles in the room as you can(placement can make or break your sub "experience").
When I got my sub, I was NOT impressed with it at all, but once I found the sweet spot for it in the room and also allowed it to break in (loosen up) it turned into a BEAST!
In other words, don't call it good without trying a few things first ;-)Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
I'm really curious...
what did you not like about the micropro2000? I am considering getting it for my 2 ch rig. Because of space constraints I need something small.Living Room 7.1 HT Rig:
I had a pair of Polk Micro Pro DSW 3000s. That was a monster duo. Best sub setup I have had.
actually i had to return the hsu 3.3 due to problems! =[ and i got my self a polk psw505 brand new for 220$ from polk for a "for now" sub! it gets here thursday i hope it makes me smile! =]Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
