NEED: RT3000p sub amp and (1) driver
newrival
newrival Posts: 2,017
edited December 2010 in Wanted (WTB) Classifieds
Hey guys, had heard there might be someone with an extra amp laying around for the RT3000p system. If this is you let me know how much you want for it :biggrin:
Additionally, I need the 8" driver from the same speaker.
any help is greatly appreciated!
Post edited by newrival on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited November 2010
    Not sure about the driver, however why don't you go with external amplification for both RT3KP's sub towers?
    I'm thinking you could get a nice stereo Adcom or a pair of monoblocks that'll work just fine for your subs. Just a suggestion since you might be in the market for awhiiiiiiiiile if you're looking for a direct replacement.
    Goodluck!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    Tony M Posts: 11,618
    newrival wrote: »
    I have a spare amp but my price is now 300.00
    Good luck on the driver. I have seen a similar driver at Parts express and it's made for Miller Krysel speakers. It looks similar but doubt it is of the same caliber.
    can't locate the one on parts express that looks like it was made for Miller Krysel anywhere online. It might be in a catalogue I have from them.:wink:
  • rtart
    rtart Posts: 848
    I bought a spare sub module about 18 months ago to have as spares for my set of RT3000ps. The amp works fine, but I'm keeping it since there basically are none left. I do have two drivers. If you get your amplification situation worked out and need one, let me know and we can work something out.
    You may also want to do some research to see if the RT2000p's use the same sub driver. I had a couple pairs and it seems like they looked the same, but I wouldn't swear to it. Might make it easier to find one. I know the amps are different, but finding a 'donor' pair of Rt2000p's and modding the amps to work would be cheaper, perhaps.
    Also, seems like there was some info in thread about how to fix the amps. It's been a while, but might be worth looking for. As I recall, someone changed out the caps, or did some minor component replacement and fixed their amp. May be worth a try, since, as Grandpa used to say, "Trying to fix somethin' that's already broke ain't gonna hurt it none."
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • newrival
    rtart wrote: »
    pm sent.
    thanks!!
  • newrival
    thanks for checking, tony.
  • newrival
    Rtart, let me know that you get my pm. I'm very interested in your driver. Thanks tons.
  • rtart
    rtart Posts: 848
    Easy transaction with newrival. Sold him one driver, and he has installed it.
    HD-A35 HD DVD
