Are MW6503's a good replacement for MW6511's?
Fongolio
In a different post I told of my SDA-1C's getting two blown MW6511's. They are no longer available from Polk Customer Service. Doing research I've learned that at one point Polk CS has recommended using MW6503's as a replacement for 6511's. Has anyone here had experience with these as replacemnts to their 6511's? They are electrically compatible (similar impedence ratings) but the 6503 has a stiffer suspension and therefore must voice differently. I can't find any 6511's new or used and must therefore seek alternates and the 6503's appear to be the closest match. Please help.
Kelvin
PS Walter at Polk CS is recommending 6510's to replace 6511's but the 10's are rated 8 ohm and the 11's are 4 ohm. This is NOT the correct replacement. I just want a straight informed answer to what will make a good alternative.
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
No one? Help!SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Nitty Gritty 1.5FI RCM -
for a while I used a 6503 in place of a 6511 in my 2.3's when I finally found a 6511 and changed it out I could not tell a difference at all. I would say go for it and be on the lookout for some 6511's. Is Polk ever going to get any new ones in?
What about 6502's? -
6502's are 4 ohms.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
They all have different parameters but I've used mismatched drivers to get by on more than one occasion. You should find the right one.....CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Not to get too far off track Fongolio.
Has there ever been any formal writing on what exactly the differences are between all of the MWXXXX's.
I have often wondered this. -
Vette C6.r wrote: »Not to get too far off track Fongolio.
No problem. I'd love to know this answer as well.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Yeah, me too!! I've searched to find the differences, mainly ohm rating of each, but have come up empty handed. Is there a list somewhere?Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
I'll post the information later. I have it in some emails.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I blew one of my 6511's on my right SDA-1C. I had a set of RTA-12Bs lying around, so I removed a 6503 MW from one and replaced the blown 6511 with the 6503. I also could not tell a difference in sound between the two. I am still on the lookout for a replacement 6511 (and 6503 for that matter), but until I find one, I'm quite happy running the 6503 as a replacement for the 6511.
Thanks Doro.
I think a sticky might be in order. -
I couldn't find the specs for the 6511. Here are the specs for the 6503.
Driver: MW 6503 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 29.8600 Hz (Free air resonance)
Vas: 3.0017 ft^3 (Compliance volume)
Qts: 0.3100 Total Q
Qms: 1.7680 Mechanical Q
Qes: 0.3760 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5400 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated powerStan
Main 2ch:
HT:
Other stuff:
I wonder, would this Dayton WT3 woofer tester be of any value to measure the different drivers? Anybody have any experience with it?____________________
Pool: Atrium 60's/45's -
It's here on the forum as well, I hate our search engine but maybe someone bookmarked it.
You are correct Heiney....forgot about that completely. Either way, we should get it stickied, per suggestion, so the basics are known.
I found out some new information about the SL series on the RT55 and etc models that will be useful, awesome, surprising and perhaps not so pleasing to some owners today.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I have one and found it useful. All the drivers data is in Georgia. If you go to the parts express forum someone posted their findings on there
Ben -
Any update on this Mark ???
Doro did you find the info in those e-mails ???
I would like to know this as well. I had a 6511 freeze up on me... From what I can find the 6503 is too high an ohm rating. Based on the info I have found, the 6502 is a closer match to the 6511.
Any more info on this?
Thanks!
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
Man, is there ever a lot of conflicting information about the 65XX drivers. Someone needs to create a sticky with accurate info on this. I got lucky and zardoss sold me a pair of 6511's but I may not be so lucky in the future and it would sure be good to have reliable information.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
The info I have found is that the 6503 is an 8 ohm speaker and the 6502 is a 4 ohm speaker.
They work well.I wonder, would this Dayton WT3 woofer tester be of any value to measure the different drivers? Anybody have any experience with it?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
You got 2 6511's? Can you explain the screw problem?
Thanks,
I ordered and recieved 2 mw-11's this month from Polk. Not too much fun to install with the non cutout around the screw deal.
I emailed them two weeks ago and was told they are unavailable!! I'm starting to think the left hand at Polk doesn't know what the right hand is doing!. For a company known for outstanding customer service there sure is a lot of conflicting information coming from them right now, especially concerning the availability of the MW6511's. Can any Polk reps please find out for sure if these drivers are available through Polk? Many people on this forum and I'm sure others would really like a definitive answer. Thank you.
KelvinSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
dcmartinpc wrote: »You got 2 6511's? Can you explain the screw problem?
Thanks,
Don
the older drivers have cut-outs on the rubber surrounds so the screw does not bind them up. the new ones do not so you have to carefully cut them out or the screw will bind them up and distort the surround or destroy it, here is a pic of the old and new side by side.
As far as Polk CS goes I think calling is always your best bet.
Attachment not found. -
OK, now I see. First, I realized my question about the pressure not is kind of dumb, because the magnet pulls everything together
But.... I do have 2 questions...
1.) I know I may be asking a really basic question, but what epoxy should I use between the magnet and the plate? And how much should I put there. don't want to over epoxy, but want enough to hold it.
2.) What kid of epoxy should I put around the magnet and plates to keep this from happening on the other drivers.
I am going to call Polk CS on Monday to verify without question the availability of the 6511's. Heck, I am going to ask them to have someone go in the parts room and LOOK!
see http://www.polkaudio.com/forums/showthread.php?t=80334
thread about
JB WELD
and Loctite adhesive -
use any epoxy or jb weld, put thin bead toward the outside, you don't want it squeezing into the VC area then when that dries put a bead on the outside top and bottom as well. did you look for damage and test the VC for resistance?
I think the voice coil is OK. It is measuring at 3.2 ohms resistance. What kind of damage should I look for?
Thanks!
dents in the vc or coming unwound, anything that would make an attempt to re-align it unsuccessful.
I'm glad you brought this up. It appears that the factory is not cutting enough of the rubber away from around the holes. I didn't notice it at the time when I installed a new MW 65xx in my 1C's. A few weeks later i noticed that the rubber was bound up in 2 areas and I thought that the MW was defective. I used a scalpel to cut away the rubber...kinda frustrating that I had to do this. Is there any way to check if the integrity of the surround has been affected?SDA SRS 2.3TL's
SDA 2B TL's
